[Qgis-psc] [QGIS-Developer] (QGIS 2020 Grant Report) Port DB Manager Table Management Functionalities to Browser (part 2)
Tim Sutton tim at kartoza.com
Tue Sep 29 12:01:44 PDT 2020
Ah wow that is such nice work, thank you for this Ale!
Regards
Tim
On Tue, 29 Sep 2020, 08:14 Alessandro Pasotti, <apasotti at gmail.com> wrote:
> Hi,
> this is the final report about the implementation of the QEP
> https://github.com/qgis/QGIS-Enhancement-Proposals/issues/171
> The QGIS browser now exposes a new "Fields" item for vector layers
> that can be expanded to show the underlying fields, an icon identifies
> the base field type.
> A context menu is available at the fields root level and allows you to
> create a new field.
> A context menu is available at the individual fields level and allows
> you to delete the selected field.
> At the connection level a new context menu item is available and
> allows you to create a new table for all DB connections that support
> the Connections API:
> - PG
> - Spatialite
> - GPKG
> - MSSQL
> All the new functions are implemented using the new connections API
> and exposed to Python for plugins/scripts.
> There have been many other small improvements in the API and in the
> browser as part of this work such as homogenization of the
> error/warning/success reporting (now using the message bar if
> available and falling back to a dialog if it is not available) and new
> context menu entries.
> The following functions are now available in the browser tree using a
> common abstraction API:
> - create a new schema
> - delete a schema
> - rename a schema
> - create a new table/layer
> - rename table/layer
> - delete a table/layer
> - truncate a table/layer
> - refresh a materialized view
> - list fields for a table/view
> - add a new field
> - delete a field
> Thank you to the QGIS project and to all QGIS sponsors and donors that
> made this possible, a special thank goes to Nyall Dawson who helped in
> the design of the API and reviewed the code.
> Kind regards.
> Alessandro Pasotti
> QCooperative:  www.qcooperative.net
> ItOpen:   www.itopen.it
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20200929/7bca1043/attachment.html>
More information about the Qgis-psc mailing list
