[Qgis-psc] First sample outputs of telemtry work
Tim Sutton tim at kartoza.com
Thu May 12 15:37:56 PDT 2022
Ah that is a cool update! Thanks so much for your help Jonathan!
Regards
Tim
On Thu, May 12, 2022 at 8:29 PM Jonathan Moules <
jonathan-lists at lightpear.com> wrote:
> Hi Tim,
> Thanks for the login credentials. I did some fiddling with the versions:
> * Some SQL to get clean QGIS versions
> * QGIS Version 30-day graph now uses this (Major.Minor version only).
> * 20 most used full-versions (Major.Minor.Patch) for the past week (table)
> - so we can see what users are using now(ish)
> * History of QGIS version use as an area graph - very cool - got it by
> fiddling around with things I didn't understand. :-D
> * Stacked bar graph of versions. Basically the same as history-of-qgis but
> different representation (not sure as to the value of this one; happy to
> delete if no-one has a use for it).
> You can see them all a little over half-way down on the dashboard. -
> http://feed.qgis.org/metabase/public/dashboard/df81071d-4c75-45b8-a698-97b8649d7228
> Cheers,
> Jonathan
> On 2022-05-11 00:39, Tim Sutton wrote:
> Hi Jonathan
> Thanks for your email, see comments below:
> On Tue, May 10, 2022 at 9:05 PM Jonathan Moules <
>> Hi Tim,
>> This looks good; I love a good dashboard. Some thoughts & bugs:
>> * Do we have telemetry for QGIS Server?
> No - I don't think we will add this.....or at least I don't have any
> current plans.
>> * The numbers on "*QGIS Open events on Windows per day - last yea**r*"
>> seem far too low. "*QGIS Daily Opens - last 30 days*" is showing half a
>> million users a day but for windows is just ~50k a day, this despite
>> windows clearly being 90+% of users per the platform chart (well, one of
>> those platform charts...).
> Only QGIS >= 3.24 reports the platform. This figure will self correct as
> more people move to more recent builds.
>> * Alternately, the pie-chart next to it: "*QGIS Daily Opens by Platform
>> - last 30 days*" is showing 86% as being "other" platforms where
>> "others" on the chart to the left of it for what appears to be trying to
>> show the same thing is only a tiny percentage (< 6%?).
> Again this is explained by the lack of platform reporting in QGIS > 3.24
> (see the little info popups on each chart).
>> * "*QGIS Daily Opens by Version - last 30 days*" - is showing some of
>> the version numbers as integers and some as floats.
> Yes I haven't figured this out yet....it could be bogus User Agents,
> custom builds of QGIS.....something else?
>> * "*QGIS Top Movers - Yesterday*" - If I sum these up I get about
>> 100,000. Given the total number of users yesterday per the day-chart was
>> only about 25k higher than a Monday average, I get the feeling this is
>> averaging across all-time, meaning weekends will always show a low number
>> and weekdays will always show a high number (as today). I'd suggest it
>> should probably use the average for that-day, so it's comparing
>> like-for-like.
> Yeah this is a bit of an experiment. It compares the amount of opens
> yesterday to the average daily opens across all time. I don't know how
> informative it is, in future I may just remove it.
>> * "*QGIS Total Number of Opens in this Current Month*" at the top is
>> wrong - it's identical to "last 30 days" to its left. Also the very bottom
>> shows the number should be 3.5 million not 10 million.
> Thanks, fixed now.
>> * "*QGIS Total Number of Opens in this Current Month*" at the top says
>> 499,262, but the graph (*QGIS Daily Opens - last 30 days*) shows 500,359
>> for yesterday if I mouse over it.
> I'm not sure why they are different - will need to poke around some more.
>> Assuming it's SQL behind the scenes, I may be able to take a stab at it
>> if you want.
> Yes I would welcome your help. I will send you some credentials, but
> please tray to avoid running any queries that place a high load on the
> server.
> Regards
> Tim
>> Cheers,
>> Jonathan
>> On 2022-04-29 22:35, Tim Sutton wrote:
>> Hi Andreas
>> On Fri, Apr 29, 2022 at 5:00 PM Andreas Neumann <andreas at qgis.org> wrote:
>>> Hi Tim,
>> See also my answers to Régis for more context. More comments below. Note
>> that I share the dashboard publicly so look here
>> especially at the little (i) indicators which I tried to populate with
>> more defail.
>>> Looks really cool - thanks for working on this! I kind of expected the
>>> dominance of Windows as an operating system, but I am surprised to see one
>>> particular Windows (Windows 10) take such a large share. Many government
>>> agencies or companies that I know still use older Windows versions.
>> I guess MS has been working hard to make the upgrade process smoother
>> which is IMHO a good thing from a security point of view.
>>> I also wonder what hides behind some of the quite large bars in the
>>> category "Other"?
>> We can break them out if needed.
>>> When it comes to QGIS versions, I think we should better aggregate only
>>> by major versions and for now ignore the minor versions. This large
>>> fragmentation into minor/minor versions seems to lead to this gigantic
>>> large bar of "Other".
>>> Yes it is on my todo list to aggregate all 3xxyy into 3xx so they show
>> as one bucket.
>>> Question: is there any chance to put the absolute numbers in relation
>>> with the rough population size of a country. It is only natural that large
>>> countries like France, Germany, USA and Brazil open QGIS  more often than
>>> smaller countries. But put in relation with population size, the pattern
>>> could look quite different.
>> The first map already does this. The second one shows absolute numbers
>> per territory regardless of population.
>>> My cartography teachers told me that it is absolutely forbidden to use
>>> absolute numbers in choropleth maps - ABSOLUTELY FORBIDDEN ! Numbers always
>>> need to be put in relation with the size (area and/or population) of a
>>> country.
>> He is probably right but I think the world of BI (Business Intelligence)
>> has largely ignored him and the world is now littered with maps like this.
>> I still think it is interesting to see the absolute numbers by country.
>>> Thanks a lot for your work to all people involved!
>> No problem, and again let me extend the invitation to you to go onto the
>> backend and help improve the dashboard, this is just my first chicken
>> scratch. I think the real value will be to see the relative breakdown of
>> platforms, versions countries and the changes to these over time so we can
>> identify trends. In terms of absolute numbers I am still unsure if it tells
>> us a real picture of how many users we have.
>> Regards
>> Tim
>>> Andreas
>>> On Fri, 29 Apr 2022 at 15:57, Tim Sutton <tim at kartoza.com> wrote:
>>>> Hi PSC
>>>> I just wanted to give you some feedback on the work we have been doing
>>>> to use anonymised telemetry data from the feed to try to get a handle on
>>>> the number, geography and platform choice of our user base. There are
>>>> detailed notes in the image below which should explain things. Currently it
>>>> has only been running about 2 weeks so the year and month charts at the end
>>>> look the same, but you can expect these to diverge over time.
>>>> If you have other things you would like to report on with the available
>>>> data, please pop me a note. I still want to aggregate the platform  better
>>>> to lump together Win, Mac, Linux and other instead of the more granular
>>>> breakdown we get right now. I will do so when I get a chance.
>>>> I do not plan to make the link to the live dashboard public as I don't
>>>> want to put load on the feed server, but if you wish to access the
>>>> dashboard, pop me a note and I will add you.
>>>> https://user-images.githubusercontent.com/178003/165956926-a30c6c96-3b6b-4895-8afb-97e9ba0bd28c.png
>>>> Regards
>>>> Tim
>>>> Tim Sutton
>>>> Visit http://kartoza.com to find out about open source:
>>>>  * Desktop GIS programming services
>>>>  * Geospatial web development
>>>> * GIS Training
>>>> * Consulting Services
>>>> Tim is a member of the QGIS Project Steering Committee
>>>> _______________________________________________
>>>> Qgis-psc mailing list
>>>> Qgis-psc at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/qgis-psc
>>> Andreas Neumann
>>> QGIS.ORG board member (treasurer)
>> Tim Sutton
>> * GIS Training
>> Qgis-psc mailing listQgis-psc at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/qgis-psc
> Tim Sutton
> * GIS Training
Tim Sutton
* GIS Training
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20220512/d6476100/attachment-0001.htm>
More information about the Qgis-psc mailing list
