[Qgis-psc] QGIS - QT6 Build Status Report
Régis Haubourg
regis at qgis.org
Wed Dec 13 02:46:33 PST 2023
Hi Ale,
thanks lot for this work.
If I understand correctly, the path to circumvent html vectorisation
through intermediate pdf might work but brings a one-man library in the
loop and a fragile dependency to the pdf format.
Even if the previous experience let us pessimistic about the possibility
of a Qt's upstream work, I would explore this possibility in any case.
Because Qt needs to know downstream projects need it.
Because fixing upstream is always more efficient.
Because it is not expensive to ask KDAB and ask Qt's project.
Because smart workarounds are fragile and in the end a Velociraptor
appears from the bushes and eats you alive.
Is there any other major blocker ?
Regards
Régis
On 12/12/2023 14:15, Alessandro Pasotti via QGIS-PSC wrote:
> Hi,
> as you probably know during the developers meeting in s-Hertogenbosch
> it was decided to allocate a budget for developers that wanted to
> dedicate some time to remove the blockers that prevented QGIS to be
> eventually migrated to QT6.
> I volunteered to coordinate the effort and organized a few meetings to
> track the advancement of the efforts.
> The good news is that thanks to the efforts and the brilliant work of
> the participants we now have made significant steps towards the goal.
> Here are the last QT6 meeting minutes:
> https://docs.google.com/document/d/1D9X3pMXJgB1pIs2sFX5O22-TJEmLYuA4ujYis7EGXpE
> Kind regards.
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20231213/cd30f5f2/attachment.htm>
More information about the QGIS-PSC
