[Qgis-psc] Is updating of the MacOS version planned?
Alexandre Neto senhor.neto at gmail.com
Wed Mar 22 15:37:57 PDT 2023
Hello Erland,
Meanwhile, you may want to try installing QGIS using conda-forge. It uses
one of the latest versions of gdal, so it might work for you.
Here's a blog post I have write about how to install and run it.
https://aneto.pt/posts/tutorials/2019-05-29-using-qgis-from-conda/
I don't have a mac, so I don't know if everything works correctly, but give
it a try.
Best regards,
Alexandre Neto
A terça, 21/03/2023, 16:22, Erland Flaten via QGIS-PSC <
qgis-psc at lists.osgeo.org> escreveu:
> Hello. I just found out that the reason I couldn’t get the Lable tools to
> work is because the MacOS version of QGIS 3.30 has an old GDAL-thing
> inside.
> When I did the same operation on windows version, also 3.30, it worked
> fine. One thing that don’t work is change text size with Lable properties.
> I get error message that says the layer can’t be  set editable. The
> datasource is FGDB and I used the same data and files for both the PC and
> the Mac.
> *I hope the GDAL can be updated soon, and possible other important stuff
> on the MacOS build aswell. *
> Thanks for making an app that is very nice! I just discovered it so I am a
> beginner.
> (i hope i didn’t post this twice)
> Erland Flaten
> Manager Norwegian Trekking Association.
> QGIS-PSC mailing list
> QGIS-PSC at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20230322/7d008552/attachment.htm>
More information about the QGIS-PSC mailing list
