[Qgis-psc] Is updating of the MacOS version planned?
Nyall Dawson nyall.dawson at gmail.com
Wed Mar 22 15:17:48 PDT 2023
On Wed, 22 Mar 2023 at 02:22, Erland Flaten via QGIS-PSC
<qgis-psc at lists.osgeo.org> wrote:
> Hello. I just found out that the reason I couldn’t get the Lable tools to work is because the MacOS version of QGIS 3.30 has an old GDAL-thing inside.
> When I did the same operation on windows version, also 3.30, it worked fine. One thing that don’t work is change text size with Lable properties. I get error message that says the layer can’t be  set editable. The datasource is FGDB and I used the same data and files for both the PC and the Mac.
> I hope the GDAL can be updated soon, and possible other important stuff on the MacOS build aswell.
> Thanks for making an app that is very nice! I just discovered it so I am a beginner.
I'd like to +1 this question, and ask PSC if the topic can be raised
at the next PSC meeting. The MacOS builds are in a rather sorry state
right now (my understanding is that they are on life-support only
thanks once again to Jürgen's efforts!), and are needing some love to
update all the library versions used and fix the notarisation
handling. I believe a rethink in how we approach the MacOS packaging
is overdue and a better, long-term viable solution determined....
Thanks for the consideration!
Nyall
> (i hope i didn’t post this twice)
> Erland Flaten
> Manager Norwegian Trekking Association.
> QGIS-PSC mailing list
> QGIS-PSC at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
More information about the QGIS-PSC mailing list
