[Qgis-psc] QGIS grant report: Improve test result handling on QGIS CI
Alessandro Pasotti apasotti at gmail.com
Sun Nov 26 23:16:13 PST 2023
On Mon, Nov 27, 2023 at 8:09 AM Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Mon, 27 Nov 2023, 4:56 pm Alessandro Pasotti, <apasotti at gmail.com> wrote:
>> Hi Nyall,
>> good news, thank you for this improvement!
>> Just a quick question, in the linked PR:
>> https://github.com/qgis/QGIS/pull/55417#issuecomment-1826995755
>> comment the instructions say:
>> "The full test report (included comparison of rendered vs expected
>> images) can be found under the 'Checks' tab - 'QGIS tests',
>> 'Artifacts' section as test-results-5."
>> But I couldn't find any test-results-5 in the artifacts section, there are only:
>> Artifacts
>> build-22.04-qt5.tgz
>> build-38-qt6.tgz
> That's caused by a limitation in GitHub API. We can't retrieve the workflow run id in an action, so that link will always just point to the most recent workflow run for the PR.
> And in this case I reverted the change causing a test failure, so the most recent workflow doesn't have the failure report.
> Hope that makes sense!
Yes, thanks for clarifying.
Alessandro Pasotti
QCooperative:  www.qcooperative.net
ItOpen:   www.itopen.it
More information about the QGIS-PSC mailing list
