[Qgis-psc] Call for reviews of grant programme 2024 voting results
Anita Graser anitagraser at gmx.at
Mon Apr 29 10:25:55 PDT 2024
Dear fellow PSC members,
The voting for the 2024 grant programme has closed and I have calculated the results.
As specified in the process description, the computations should be reviewed and confirmed by at least two PSC members. Therefore, I'd like to invite you to have a look.
For your convenience, here's the summary of the process:
The successful proposals are determined as follows: The calculation of votes is done by summing up the votes for each proposal. We then rank each proposal according to the number of votes it has received.
Grants will be allocated by working sequentially from top scoring proposal to lowest until all the funds have been allocated. If the top candidates do not exactly coincide with the total grant budget, we may, depending on available funds, ‘top up’ the grant budget to include the next-in-line proposal and use up all of the available funds. The Google Drive GrantProgramme folder contains spreadsheets with the corresponding formulas.
The computed results should be reviewed and confirmed by at least two PSC members before publishing the results.
Regards,
Anita
Anita Graser
Home: http://anitagraser.com
Mastodon: @underdarkgis at fosstodon.org
More information about the QGIS-PSC mailing list
