[Qgis-psc] Call for reviews of grant programme 2024 voting results
Marco Bernasocchi marco at qgis.org
Mon Apr 29 11:14:34 PDT 2024
Hi Anita, thanks a lot for your work on this.
I checked the numbers and they look correct to me.
Looking forward to seeing the results of the proposals:)
Cheers Marco
On Mon, 29 Apr 2024, 19:31 Anita Graser via QGIS-PSC, <
qgis-psc at lists.osgeo.org> wrote:
> Dear fellow PSC members,
> The voting for the 2024 grant programme has closed and I have calculated
> the results.
> As specified in the process description, the computations should be
> reviewed and confirmed by at least two PSC members. Therefore, I'd like to
> invite you to have a look.
> For your convenience, here's the summary of the process:
> The successful proposals are determined as follows: The calculation of
> votes is done by summing up the votes for each proposal. We then rank each
> proposal according to the number of votes it has received.
> Grants will be allocated by working sequentially from top scoring proposal
> to lowest until all the funds have been allocated. If the top candidates do
> not exactly coincide with the total grant budget, we may, depending on
> available funds, ‘top up’ the grant budget to include the next-in-line
> proposal and use up all of the available funds. The Google Drive
> GrantProgramme folder contains spreadsheets with the corresponding formulas.
> The computed results should be reviewed and confirmed by at least two PSC
> members before publishing the results.
> Regards,
> Anita
> Anita Graser
> Home: http://anitagraser.com
> Mastodon: @underdarkgis at fosstodon.org
> QGIS-PSC mailing list
> QGIS-PSC at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20240429/da34efe9/attachment.htm>
More information about the QGIS-PSC mailing list
