[Qgis-psc] Process for approval of newly posted QGIS plugins
Johannes Kröger (WhereGroup) johannes.kroeger at wheregroup.com
Mon Mar 18 06:34:08 PDT 2024
Hi Bart,
It is marked *experimental* so it will only be visible to QGIS profiles
that have the "show experimental plugins" (or some similar wording)
checkbox active in the plugin manager settings.
Cheers, Hannes
On 18.03.24 13:39, Bart Duijndam via QGIS-PSC wrote:
> Greetings Kaplan, Richard,
> I just received a confirmation email that my plugin has been approved,
> much appreciated !
> Plugin Roll approval by zimbogisgeek.
> The plugin version "[3305] Roll 0.2.1 Experimental" is now approved
> Link: http://plugins.qgis.org/plugins/roll/
> The plugin is however *not visible* in the list of “All plugins” or
> “Not installed plugins” in QGIS.
> Does it take some more time to “percolate through” to the list of
> available plugins, or is there more to it ?
> Please advise...
> Cheers,
> Bart
> *From:*Bart.Duijndam at ziggo.nl <Bart.Duijndam at ziggo.nl>
> *Sent:* Friday, 15 March 2024 12:50
> *To:* 'Lior Kaplan' <lior at kaplanopensource.co.il>; 'Richard
> Duivenvoorde' <rdmailings at duif.net>
> *Cc:* 'qgis-psc' <qgis-psc at lists.osgeo.org>
> *Subject:* RE: [Qgis-psc] Process for approval of newly posted QGIS
> plugins
> Hi Kaplan, Richard,
> Thanks very much for your help.
> The plugin’s name is “*Roll*”.
> The reason you may not have found it against my last name ‘duijndam’
> might be because my OSGEO user  ID is “MrBeee”.
> This is the same ID as I use for publishing on GitHub.
> https://github.com/MrBeee/roll
> Best regards,
> Bart
> *From:*Lior Kaplan <lior at kaplanopensource.co.il>
> *Sent:* Friday, 15 March 2024 12:18
> *To:* Richard Duivenvoorde <rdmailings at duif.net>
> *Cc:* Bart.Duijndam at ziggo.nl; qgis-psc <qgis-psc at lists.osgeo.org>
> *Subject:* Re: [Qgis-psc] Process for approval of newly posted QGIS
> plugins
> You can add me as a reviewer, happy to help.
> Kaplan
> On Fri, Mar 15, 2024, 13:05 Richard Duivenvoorde via QGIS-PSC
> <qgis-psc at lists.osgeo.org> wrote:
>     On 3/15/24 11:56 AM, Bart Duijndam via QGIS-PSC wrote:
>     > *             Is there a focal point, taking care of approvals ?
>     Well, there are some volunteers doing it in their free time.
>     > *             What requirements does a new plugin have to fulfill ?
>     https://plugins.qgis.org/publish/ (think you could have googled
>     that yourself, I did :-) )
>     > *             How long does this process take to be completed ?
>     Normally a couple of days, if in a hurry: sent a mail (like you
>     did now).
>     Then hopefully one of the 'approvers' sees this and has time.
>     What is the plugin name? It is harder to find it based on the 3305 id.
>     I also could not find a plugin searching for your name 'duijndam'.
>     Regards,
>     _______________________________________________
>     QGIS-PSC mailing list
>     QGIS-PSC at lists.osgeo.org
>     https://lists.osgeo.org/mailman/listinfo/qgis-psc
Johannes Kröger / GIS-Entwickler/-Berater
FOSSGIS Konferenz
20.-23. März 2024 in Hamburg
https://www.fossgis-konferenz.de/2024/
WhereGroup-Beiträge auf der FOSSGIS
https://wheregroup.com/unternehmen/aktuelles/
WhereGroup GmbH
c/o KK03 GmbH
Lange Reihe 29
20099 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20240318/6a1bfab5/attachment-0001.htm>
More information about the QGIS-PSC mailing list
