[Qgis-psc] Process for approval of newly posted QGIS plugins
Bart Duijndam
bart.duijndam at ziggo.nl
Mon Mar 18 07:57:44 PDT 2024
Hi Hannes,
Thanks for clarifying, I completely overlooked that, apologies.
I'check immediately when I'm back home.
Cheers.
Bart
Get BlueMail for Android
On 18 Mar 2024, 14:34, at 14:34, "Johannes Kröger" <johannes.kroeger at wheregroup.com> wrote:
>Hi Bart,
>It is marked *experimental* so it will only be visible to QGIS profiles
>that have the "show experimental plugins" (or some similar wording)
>checkbox active in the plugin manager settings.
>Cheers, Hannes
>On 18.03.24 13:39, Bart Duijndam via QGIS-PSC wrote:
>> Greetings Kaplan, Richard,
>> I just received a confirmation email that my plugin has been
>approved,
>> much appreciated !
>> Plugin Roll approval by zimbogisgeek.
>> The plugin version "[3305] Roll 0.2.1 Experimental" is now approved
>> Link: http://plugins.qgis.org/plugins/roll/
>> The plugin is however *not visible* in the list of “All plugins” or
>> “Not installed plugins” in QGIS.
>> Does it take some more time to “percolate through” to the list of
>> available plugins, or is there more to it ?
>> Please advise...
>> Cheers,
>> Bart
>> *From:*Bart.Duijndam at ziggo.nl <Bart.Duijndam at ziggo.nl>
>> *Sent:* Friday, 15 March 2024 12:50
>> *To:* 'Lior Kaplan' <lior at kaplanopensource.co.il>; 'Richard
>> Duivenvoorde' <rdmailings at duif.net>
>> *Cc:* 'qgis-psc' <qgis-psc at lists.osgeo.org>
>> *Subject:* RE: [Qgis-psc] Process for approval of newly posted QGIS
>> plugins
>> Hi Kaplan, Richard,
>> Thanks very much for your help.
>> The plugin’s name is “*Roll*”.
>> The reason you may not have found it against my last name ‘duijndam’
>> might be because my OSGEO user ID is “MrBeee”.
>> This is the same ID as I use for publishing on GitHub.
>> https://github.com/MrBeee/roll
>> Best regards,
>> Bart
>> *From:*Lior Kaplan <lior at kaplanopensource.co.il>
>> *Sent:* Friday, 15 March 2024 12:18
>> *To:* Richard Duivenvoorde <rdmailings at duif.net>
>> *Cc:* Bart.Duijndam at ziggo.nl; qgis-psc <qgis-psc at lists.osgeo.org>
>> *Subject:* Re: [Qgis-psc] Process for approval of newly posted QGIS
>> plugins
>> You can add me as a reviewer, happy to help.
>> Kaplan
>> On Fri, Mar 15, 2024, 13:05 Richard Duivenvoorde via QGIS-PSC
>> <qgis-psc at lists.osgeo.org> wrote:
>> On 3/15/24 11:56 AM, Bart Duijndam via QGIS-PSC wrote:
>> > * Is there a focal point, taking care of approvals
>> Well, there are some volunteers doing it in their free time.
>> > * What requirements does a new plugin have to
>fulfill ?
>> https://plugins.qgis.org/publish/ (think you could have googled
>> that yourself, I did :-) )
>> > * How long does this process take to be completed ?
>> Normally a couple of days, if in a hurry: sent a mail (like you
>> did now).
>> Then hopefully one of the 'approvers' sees this and has time.
>> What is the plugin name? It is harder to find it based on the
>3305 id.
>> I also could not find a plugin searching for your name
>'duijndam'.
>> Regards,
>> QGIS-PSC mailing list
>> QGIS-PSC at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/qgis-psc
>Johannes Kröger / GIS-Entwickler/-Berater
>FOSSGIS Konferenz
>20.-23. März 2024 in Hamburg
>https://www.fossgis-konferenz.de/2024/
>WhereGroup-Beiträge auf der FOSSGIS
>https://wheregroup.com/unternehmen/aktuelles/
>WhereGroup GmbH
>c/o KK03 GmbH
>Lange Reihe 29
>20099 Hamburg
>Germany
>Tel: +49 (0)228 / 90 90 38 - 36
>Fax: +49 (0)228 / 90 90 38 - 11
>www.wheregroup.com
>Geschäftsführer:
>Olaf Knopp, Peter Stamm
>Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20240318/9c723823/attachment.htm>
More information about the QGIS-PSC
