[Qgis-psc] Process for approval of newly posted QGIS plugins
Johannes Kröger (WhereGroup)
johannes.kroeger at wheregroup.com
Mon Mar 18 07:59:28 PDT 2024
Been there, done that. ;)
Fingers crossed for your test and thanks for your plugin, sounds
fascinating!
On 18.03.24 15:57, Bart Duijndam wrote:
> Hi Hannes,
> Thanks for clarifying, I completely overlooked that, apologies.
> I'check immediately when I'm back home.
> Cheers.
> Bart
> Get BlueMail for Android <https://bluemail.me>
> On 18 Mar 2024, at 14:34, "Johannes Kröger"
> <johannes.kroeger at wheregroup.com> wrote:
> Hi Bart,
> It is marked *experimental* so it will only be visible to QGIS
> profiles that have the "show experimental plugins" (or some
> similar wording) checkbox active in the plugin manager settings.
> Cheers, Hannes
> On 18.03.24 13:39, Bart Duijndam via QGIS-PSC wrote:
>> Greetings Kaplan, Richard,
>> I just received a confirmation email that my plugin has been
>> approved, much appreciated !
>> Plugin Roll approval by zimbogisgeek.
>> The plugin version "[3305] Roll 0.2.1 Experimental" is now approved
>> Link: http://plugins.qgis.org/plugins/roll/
>> The plugin is however *not visible* in the list of “All plugins”
>> or “Not installed plugins” in QGIS.
>> Does it take some more time to “percolate through” to the list of
>> available plugins, or is there more to it ?
>> Please advise...
>> Cheers,
>> Bart
>> *From:*Bart.Duijndam at ziggo.nl <Bart.Duijndam at ziggo.nl>
>> *Sent:* Friday, 15 March 2024 12:50
>> *To:* 'Lior Kaplan' <lior at kaplanopensource.co.il>; 'Richard
>> Duivenvoorde' <rdmailings at duif.net>
>> *Cc:* 'qgis-psc' <qgis-psc at lists.osgeo.org>
>> *Subject:* RE: [Qgis-psc] Process for approval of newly posted
>> QGIS plugins
>> Hi Kaplan, Richard,
>> Thanks very much for your help.
>> The plugin’s name is “*Roll*”.
>> The reason you may not have found it against my last name
>> ‘duijndam’ might be because my OSGEO user ID is “MrBeee”.
>> This is the same ID as I use for publishing on GitHub.
>> https://github.com/MrBeee/roll
>> Best regards,
>> Bart
>> *From:*Lior Kaplan <lior at kaplanopensource.co.il>
>> *Sent:* Friday, 15 March 2024 12:18
>> *To:* Richard Duivenvoorde <rdmailings at duif.net>
>> *Cc:* Bart.Duijndam at ziggo.nl; qgis-psc <qgis-psc at lists.osgeo.org>
>> *Subject:* Re: [Qgis-psc] Process for approval of newly posted
>> QGIS plugins
>> You can add me as a reviewer, happy to help.
>> Kaplan
>> On Fri, Mar 15, 2024, 13:05 Richard Duivenvoorde via QGIS-PSC
>> <qgis-psc at lists.osgeo.org> wrote:
>> On 3/15/24 11:56 AM, Bart Duijndam via QGIS-PSC wrote:
>> > * Is there a focal point, taking care of
>> approvals ?
>> Well, there are some volunteers doing it in their free time.
>> > * What requirements does a new plugin have to
>> fulfill ?
>> https://plugins.qgis.org/publish/ (think you could have
>> googled that yourself, I did :-) )
>> > * How long does this process take to be completed ?
>> Normally a couple of days, if in a hurry: sent a mail (like
>> you did now).
>> Then hopefully one of the 'approvers' sees this and has time.
>> What is the plugin name? It is harder to find it based on the
>> 3305 id.
>> I also could not find a plugin searching for your name
>> 'duijndam'.
>> Regards,
>> QGIS-PSC mailing list
>> QGIS-PSC at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/qgis-psc
> Johannes Kröger / GIS-Entwickler/-Berater
> FOSSGIS Konferenz
> 20.-23. März 2024 in Hamburg
> https://www.fossgis-konferenz.de/2024/
> WhereGroup-Beiträge auf der FOSSGIS
> https://wheregroup.com/unternehmen/aktuelles/
> WhereGroup GmbH
> c/o KK03 GmbH
> Lange Reihe 29
> 20099 Hamburg
> Germany
> Tel: +49 (0)228 / 90 90 38 - 36
> Fax: +49 (0)228 / 90 90 38 - 11
> www.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
FOSSGIS Konferenz
WhereGroup GmbH
c/o KK03 GmbH
Lange Reihe 29
20099 Hamburg
Germany
www.wheregroup.com
Geschäftsführer:
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20240318/cbd4249c/attachment-0001.htm>
More information about the QGIS-PSC
