[QGIS-pt] Boas
Alexandre Neto senhor.neto gmail.com
Quarta-Feira, 17 de Dezembro de 2014 - 15:26:10 PST
C++
http://qt-project.org/
2014-12-17 23:16 GMT+00:00 Vinicius Silva <x3msnake  gmail.com>:
> o Qt é escrito em quê?
> No dia 17 de dezembro de 2014 às 23:06, Alexandre Neto <
> senhor.neto  gmail.com> escreveu:
>> Aqui vai a resposta do Nyall.
>> Aparentemente a implementação do CMYK terá de ser feita primeiro no Qt
>> (que é a framework sobre a qual o qgis está criado).
>> E ao que parece os últimos pedidos nesse sentido não surtiram grande
>> efeito. Não sabemos se no caso do Qt é possível patrocinar este tipo de
>> melhorias.
>> On 18 December 2014 at 01:31, Alexandre Neto <senhor.neto  gmail.com>
>> wrote:>> Hello everyone,>> Does anyone know if there are any plans for
>> implementing CMYK color mode in> QGIS?I did a bit of research yesterday and
>> it looks like we're out of luckuntil the underlying Qt libraries (QPainter,
>> QPrinter, QtSvg) gainsupport for CMYK. We could add support for selecting
>> CMYK colours intothe new colour picker, but currently all of the export
>> optionsavailable in Qt convert colours back to RGB prior to export.> If
>> there are no plans for that, can someone give me anideia of what would>
>> need to be done?It would need to be implemented in Qt, but I can't find
>> muchinformation about whether this is planned or not. Here's a couple
>> ofrelevant reports (with almost zero activity):
>> https://bugreports.qt-project.org/browse/QTBUG-896https://bugreports.qt-project.org/browse/QTBUG-86https://bugreports.qt-project.org/browse/QTBUG-21276I'm
>> also not sure if Qt has a culture of sponsored targeteddevelopment, or who
>> you could get to tackle this... I'm interested toknow any findings you have
>> though, as there's a number of similar Qtlimitations which really hold us
>> back:
>> https://bugreports.qt-project.org/browse/QTBUG-28636https://bugreports.qt-project.org/browse/QTBUG-36302https://bugreports.qt-project.org/browse/QTBUG-6582(also
>> there's a report that I can't find right now about allowingediting of PDF
>> metadata)Nyall
>> Em 16/12/2014 07:21, "Luigi Pirelli" <luipir  gmail.com> escreveu:
>> Hola Alexander,
>>> envia el correo tambien en qgis-developer para fomentar la discusión
>>> ciao Luigi Pirelli
>>> 2014-12-16 0:46 GMT+01:00 Alexandre Neto <senhor.neto  gmail.com>:
>>>> Boa noite,
>>>> Já mandei um email ao Nyall a saber se existem planos para a introdução
>>>> do CMYK no QGIS, e o que seria preciso para o implementar.
>>>> Vamos ver o que ele responde.
>>>> Abraço,
>>>> Alexandre Neto
>>>> 2014-12-15 19:34 GMT+00:00 Vinicius Silva <x3msnake  gmail.com>:
>>>>> Aqui está mais uma biblioteca que tem muito potencial, se integrada
>>>>> com o Qgis
>>>>> [image: Tree]
>>>>> http://xxyxyz.org/flat
>>>>> No dia 15 de dezembro de 2014 às 19:30, Vinicius Silva <
>>>>> x3msnake  gmail.com> escreveu:
>>>>>> Boas Luigi
>>>>>> Encontrei uma biblioteca de gestão de cores que penso pode ser um
>>>>>> meio para acelerar o processo de criação de um Plug ou integração do CMYK
>>>>>> no
>>>>>> http://www.cazabon.com/pyCMS/
>>>>>> http://unix.stackexchange.com/questions/22193/how-can-i-generate-cmyk-images-via-the-command-line-under-linux
>>>>>> Vou então perguntar no freenode. Thanks
>>>>>> Abraços Master Luigi
>>>>>> No dia 15 de dezembro de 2014 às 18:45, Luigi Pirelli <
>>>>>>> Hola vinicius, el paso es ir al irc de freenode #qgis y preguntar
>>>>>>> allí en inglés, creo que marco y nyall te pueden decir exactamente la parte
>>>>>>> de código relacionada con cmyk.
>>>>>>> Esto para empezar... Y después en qgis-developer que seguro hay
>>>>>>> personas interesadas. Cuenta que seguro puede crear un pledge para
>>>>>>> financiarte el desarrollo.
>>>>>>> Cual Luigi Pirelli
>>>>>>> On Monday, 15 December 2014, Hugo <hfpmartins  gmail.com> wrote:
>>>>>>>> Olá Vinicius,
>>>>>>>> Bem vindo...
>>>>>>>> Vamos esperar a ver se o Alex sabe onde isso está. Caso contrário
>>>>>>>> logo te ajudo a encontrar esse pedaço de código.
>>>>>>>> O plugin pode ser uma ideia... mas fixe fixe era isso entrar para o
>>>>>>>> core do QGIS. O Alex ficou de falar com o developer que anda mais activo
>>>>>>>> nessa componente para saber como está a coisa. Vamos esperar um pouco pelo
>>>>>>>> feedback.
>>>>>>>> Grande abc,
>>>>>>>> No dia 15 de dezembro de 2014 às 14:05, Vinicius Silva <
>>>>>>>>> Boas Pessoal
>>>>>>>>> Já cá estou inscrito ;)
>>>>>>>>> Em que parte ou partes do Source Code do Qgis está o sistema de
>>>>>>>>> cores?
>>>>>>>>> Gostava de dar uma vista de olhos para tentar compreender se será
>>>>>>>>> muito difícil adaptar o sistema para usar cores CMYK em vez das cores de
>>>>>>>>> sistema.
>>>>>>>>> Caso contrario poderia-se produzir um plugin de exportação que
>>>>>>>>> identifique as cores utilizadas e permita ao utilizador indicar quais as
>>>>>>>>> cores.
>>>>>>>>> Seria interessante ter exportação para PDF em CMYK Georeferenciado
>>>>>>>>> Com os melhores cumprimentos,
>>>>>>>>> Vinicius Silva
>>>>>>>>> _______________________________________________
>>>>>>>>> QGIS-pt mailing list
>>>>>>>>> QGIS-pt  lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/qgis-pt
>>>>>>>> Hugo Martins
>>>>>> Vinicius Silva
>>>>> Vinicius Silva
> Vinicius Silva
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/qgis-pt/attachments/20141217/9f9ec1f3/attachment.html>
More information about the QGIS-pt mailing list
