[Qgis-tr] GUI showing untranslated strings where it should not
Artem Popov artfwo at gmail.com
Fri Jun 1 10:59:47 PDT 2012
2012/5/31 Richard Duivenvoorde <rdmailings at duif.net>:
> On 05/31/2012 04:23 PM, QGIS Brasil Comunidade brasileira wrote:
>> How can I compile into Ubuntu 12.04?  I would like to see with pt_BR
>> translation.
> Hi Arthur,
> not sure if I understand you correctly but I will try to give you some
> answers:
> - instructions to have a QGIS master on 12.04 without compiling you can find
> here:
> http://hub.qgis.org/projects/quantum-gis/wiki/Download#263-Master
> - if you want to compile it yourself, find good instructions in the INSTALL
> document:
> https://github.com/qgis/Quantum-GIS/blob/master/INSTALL
> You can load a qgis_pt_BR.ts-file into the QT linguist program, and via
> File/Release create a qm file from that ts file
> If you copy that qgis_pt_BR.qm-file to the share/qgis/i18n directory and
> restart QGIS again, you should see the new strings.
>> I'd verified some differences between this last TS file in comparative
>> with the TS translated at april. The current has 7700 against 8500 of
>> april. Is this correct?
> I cannot verify that for you, but that is probably correct. Werner Macho
> always updates the ts files just before the release (it means running
> scripts/update_ts.sh which you can do yourself also).
Instead of compiling you may always use the nightly builds from here:
Regards,
--Artem
More information about the Qgis-tr mailing list
