[Qgis-tr] GUI showing untranslated strings where it should not
QGIS Brasil Comunidade brasileira qgisbrasil at gmail.com
Fri Jun 1 12:34:14 PDT 2012
Tks Artem.
The procedure works fine. Is very important see the translated strings
immediately to adjust contexts.
Regards.
2012/6/1 Artem Popov <artfwo at gmail.com>
> 2012/5/31 Richard Duivenvoorde <rdmailings at duif.net>:
> > On 05/31/2012 04:23 PM, QGIS Brasil Comunidade brasileira wrote:
> >> How can I compile into Ubuntu 12.04?  I would like to see with pt_BR
> >> translation.
> > Hi Arthur,
> > not sure if I understand you correctly but I will try to give you some
> > answers:
> > - instructions to have a QGIS master on 12.04 without compiling you can
> find
> > here:
> > http://hub.qgis.org/projects/quantum-gis/wiki/Download#263-Master
> > - if you want to compile it yourself, find good instructions in the
> INSTALL
> > document:
> > https://github.com/qgis/Quantum-GIS/blob/master/INSTALL
> > You can load a qgis_pt_BR.ts-file into the QT linguist program, and via
> > File/Release create a qm file from that ts file
> > If you copy that qgis_pt_BR.qm-file to the share/qgis/i18n directory and
> > restart QGIS again, you should see the new strings.
> >> I'd verified some differences between this last TS file in comparative
> >> with the TS translated at april. The current has 7700 against 8500 of
> >> april. Is this correct?
> > I cannot verify that for you, but that is probably correct. Werner Macho
> > always updates the ts files just before the release (it means running
> > scripts/update_ts.sh which you can do yourself also).
> Instead of compiling you may always use the nightly builds from here:
> Regards,
> --Artem
> Qgis-tr mailing list
> Qgis-tr at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-tr
*Comunidade QGISBrasil*
www.qgisbrasil.org
comunidade at qgisbrasil.org
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20120601/86a3438f/attachment.html>
More information about the Qgis-tr mailing list
