[Qgis-tr] Qgis-tr Digest, Vol 34, Issue 13
hosham22 hosham22 at hotmail.com
Mon Oct 27 12:36:29 PDT 2014
Is there is relation between unfinished and unreviewed words.
Sent from Samsung Mobile
-------- Original message --------
Date:27/10/2014  10:00 PM  (GMT+03:00)
To: qgis-tr at lists.osgeo.org
Subject: Qgis-tr Digest, Vol 34, Issue 13
Send Qgis-tr mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
        http://lists.osgeo.org/mailman/listinfo/qgis-tr
or, via email, send a message with subject or body 'help' to
        qgis-tr-request at lists.osgeo.org
You can reach the person managing the list at
        qgis-tr-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Qgis-tr digest..."
Today's Topics:
   1. Niche question (Kari Salovaara)
   2. Spelling mistake (Stott, James)
   3. Re: Niche question (Maris Nartiss)
   4. Re: Niche question (Richard Duivenvoorde)
   5. Re: Spelling mistake (Werner Macho)
Message: 1
Date: Mon, 27 Oct 2014 01:05:09 +0200
From: Kari Salovaara <kari.salovaara at pp1.inet.fi>
To: QGIS Translation Discussions <qgis-tr at lists.osgeo.org>
Subject: [Qgis-tr] Niche question
Message-ID: <544D7E25.1010107 at pp1.inet.fi>
Content-Type: text/plain; charset=utf-8; format=flowed
in Transifex strings have basicly two modes, not translated and
translated and you'll get their amount in numbers respectively.
in QGIS (desktop) when you look Help -> About -> Translators you'll see
all languages and there's a bar which visualizes the amount how much is
translated. But that same bar shows a tooltip where You find three
different modes (!) finished, unfinished and untranslated. (Of course
the numbers don't match with Transifex, only the total is correct. But
this is not relevant now)
How this, two and three, is explained ? And why these cannot match so
that a simple fellow like me could understand this ? What is unfinished?
All the best,
Kari
Kari Salovaara
Hanko, Finland
"Volunteers do not necessarily have the time; they just have the heart."
  ~ Elizabeth Andrew
Message: 2
Date: Mon, 27 Oct 2014 09:39:37 +0000
To: "qgis-tr at lists.osgeo.org" <qgis-tr at lists.osgeo.org>
Subject: [Qgis-tr] Spelling mistake
Message-ID:
        <FA49BFC197A78E4D8E7F1200278E5F55011800A256 at fmexch1.fylkesmannen.local>
Content-Type: text/plain; charset="us-ascii"
Found a spelling mistake.
It's in Context: context_help
Occurrence ../src/core/qgscontexthelp_texts.cpp:401
It's in the long string for Delimited text file layer. There is an instance where it says linewhich. It is missing a space.
James
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20141027/22cfd616/attachment-0001.html>
Message: 3
Date: Mon, 27 Oct 2014 12:13:14 +0200
To: kari.salovaara at pp1.inet.fi,         QGIS Translation Discussions
Subject: Re: [Qgis-tr] Niche question
Message-ID:
        <CAK8GbeC4-2nVyMvLv-ze5QM2V=BQ0u7S64io9LrzQcW6wuWS8A at mail.gmail.com>
Content-Type: text/plain; charset=UTF-8
Kari,
I believe "unfinished" are the same as gettext's "fuzzy". A string is
marked fuzzy, if it has been translated but there have been some
changes in the source code of program. Most of the time it is just a
matter of accepting translation, still sometimes whole string needs to
be translated a new. Fuzzies can be generated also by "fuzzy matching"
while updating translation template file. As from the total translated
point of view - fuzzy and untranslated are the same - not displayed in
the application.
I can not comment on Transifex, as I don't use it. I am just familiar
with KDE SC translation.
M?ris.
2014-10-27 1:05 GMT+02:00 Kari Salovaara <kari.salovaara at pp1.inet.fi>:
> Hi,
> in Transifex strings have basicly two modes, not translated and translated
> in QGIS (desktop) when you look Help -> About -> Translators you'll see all
> translated. But that same bar shows a tooltip where You find three different
> modes (!) finished, unfinished and untranslated. (Of course the numbers
> don't match with Transifex, only the total is correct. But this is not
> relevant now)
> How this, two and three, is explained ? And why these cannot match so that a
> All the best,
> Kari
> Kari Salovaara
> Hanko, Finland
>  ~ Elizabeth Andrew
> Qgis-tr at lists.osgeo.org
Message: 4
Date: Mon, 27 Oct 2014 11:44:27 +0100
To: qgis-tr at lists.osgeo.org, kari.salovaara at pp1.inet.fi
Message-ID: <544E220B.3030003 at duif.net>
Content-Type: text/plain; charset=ISO-8859-1
On 27-10-14 00:05, Kari Salovaara wrote:
> Hi,
Hi Kari,
before transifex we used Qt-Linguist for translation, but still QGIS
uses all Qt tools to get translations into the application.
The user format: 'ts file' is actually an xml file which for every
string has these term's (unfinished etc) in it (have a look into one of
the i18m/qgis_xx.ts files).
The html for the bars is generated by the script tsstat.pl:
https://github.com/qgis/QGIS/blob/master/scripts/tsstat.pl#L124
the finished/unfinished counts are actually generated by the Qt command
'lrelease' which you can also run by hand:
richard at kwik/tmp$ lrelease qgis_es.ts
Updating 'qgis_es.qm'...
    Generated 10756 translation(s) (10489 finished and 267 unfinished)
    Ignored 914 untranslated source text(s)
And those counts actually is what you seen in the bar's.
As Maris already stated, I think unfinished is a string which is already
translated, but the source string is missing a punctuation or so?
HTH,
Regards,
Message: 5
Date: Mon, 27 Oct 2014 13:40:27 +0100
Subject: Re: [Qgis-tr] Spelling mistake
Message-ID:
        <CA+3oMjuzo=DwsjhOrFV3MsWE63QTLYSUBMtbr829HR24f8t5AA at mail.gmail.com>
Hi James!
Fixed in last commit!
Thanks a lot!
regards
Werner
On Mon, Oct 27, 2014 at 10:39 AM, Stott, James <fmrojst at fylkesmannen.no> wrote:
> It?s in Context: context_help
> It?s in the long string for Delimited text file layer. There is an instance
> James
End of Qgis-tr Digest, Vol 34, Issue 13
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20141027/70456007/attachment.html>
More information about the Qgis-tr mailing list
