[Qgis-tr] update the language when compiling QGIS
Werner Macho werner.macho at gmail.com
Wed Feb 18 01:19:17 PST 2015
Hi Matteo.
Doing the
./scripts/pull_ts.sh
is the correct way - but the message
tx not found only indicates that you are missing the (python) transifex client
which can be installed as
pip install transifex-client
IIRC
hope this helps
kind regards
Werner
On Wed, Feb 18, 2015 at 10:13 AM, Matteo Ghetta <matteo.ghetta at gmail.com> wrote:
> Hi all,
> I have a simple question, but I cannot deal with this issue.
> I'm compiling QGIS, but what should I do in order to update also the
> translation?
> I tried:
> ./pull_ts.sh
> inside the scripts dir, but I got an error:
> ./pull_ts.sh: line 18: scripts/update_ts.sh: No such file or directory
> so I tried
> in the main dir of the repo, but I got
> tx not found
> Am I missing something?
> Thanks to all
> Matteo
> Qgis-tr mailing list
> Qgis-tr at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-tr
More information about the Qgis-tr mailing list
