[Qgis-tr] update the language when compiling QGIS
Matteo Ghetta matteo.ghetta at gmail.com
Wed Feb 18 06:18:32 PST 2015
Hi Werner,
thanks for the reply.
I have now tx-client installed on my pc, but still problem when running
./script/pull_ts.sh
Saving translations
rm: cannot remove ‘i18n/qgis_*.ts’: No such file or directory
Restoring files...
Removing temporary files
no idea how to fix this...
Thanks
Matteo
2015-02-18 10:19 GMT+01:00 Werner Macho <werner.macho at gmail.com>:
> Hi Matteo.
> Doing the
> ./scripts/pull_ts.sh
> is the correct way - but the message
> tx not found only indicates that you are missing the (python) transifex
> client
> which can be installed as
> pip install transifex-client
> IIRC
> hope this helps
> kind regards
> Werner
> On Wed, Feb 18, 2015 at 10:13 AM, Matteo Ghetta <matteo.ghetta at gmail.com>
> wrote:
> > Hi all,
> > I have a simple question, but I cannot deal with this issue.
> > I'm compiling QGIS, but what should I do in order to update also the
> > translation?
> > I tried:
> > ./pull_ts.sh
> > inside the scripts dir, but I got an error:
> > ./pull_ts.sh: line 18: scripts/update_ts.sh: No such file or directory
> > so I tried
> > in the main dir of the repo, but I got
> > tx not found
> > Am I missing something?
> > Thanks to all
> > Matteo
> > Qgis-tr mailing list
> > Qgis-tr at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20150218/ce181cfc/attachment.html>
More information about the Qgis-tr mailing list
