[Qgis-tr] update the language when compiling QGIS
Werner Macho werner.macho at gmail.com
Wed Feb 18 06:58:26 PST 2015
Hi!
Never had this type of error ..
Are you sure you executed the pull_ts.sh script from the root
directory of a git cloned repository?
./scripts/pull_ts.sh
otherwise I have no clue what could have happened.. can you join into
the i18n dir and take a look whats inside?
regards
Werner
On Wed, Feb 18, 2015 at 3:18 PM, Matteo Ghetta <matteo.ghetta at gmail.com> wrote:
> Hi Werner,
> thanks for the reply.
> I have now tx-client installed on my pc, but still problem when running
> ./script/pull_ts.sh
> Saving translations
> rm: cannot remove ‘i18n/qgis_*.ts’: No such file or directory
> Restoring files...
> Removing temporary files
> no idea how to fix this...
> Thanks
> Matteo
> 2015-02-18 10:19 GMT+01:00 Werner Macho <werner.macho at gmail.com>:
>> Hi Matteo.
>> Doing the
>> is the correct way - but the message
>> tx not found only indicates that you are missing the (python) transifex
>> client
>> which can be installed as
>> pip install transifex-client
>> IIRC
>> hope this helps
>> kind regards
>> Werner
>> On Wed, Feb 18, 2015 at 10:13 AM, Matteo Ghetta <matteo.ghetta at gmail.com>
>> wrote:
>> > Hi all,
>> > I have a simple question, but I cannot deal with this issue.
>> > I'm compiling QGIS, but what should I do in order to update also the
>> > translation?
>> > I tried:
>> > ./pull_ts.sh
>> > inside the scripts dir, but I got an error:
>> > ./pull_ts.sh: line 18: scripts/update_ts.sh: No such file or directory
>> > so I tried
>> > in the main dir of the repo, but I got
>> > tx not found
>> > Am I missing something?
>> > Thanks to all
>> > Matteo
>> > _______________________________________________
>> > Qgis-tr mailing list
>> > Qgis-tr at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-tr
More information about the Qgis-tr mailing list
