[Qgis-tr] update the language when compiling QGIS
Matteo Ghetta matteo.ghetta at gmail.com
Wed Feb 18 07:28:20 PST 2015
it seems that after running for the first time ./script/pull_ts.sh all the
.ts files inside i18t have been deleted due to:
./script/pull_ts.sh
Pulling new translations...
Exception: No user credentials found for host https://www.transifex.com.
Edit ~/.transifexrc and add the appropriate info in there.
Restoring files...
Removing temporary files
weird (for me) is that if I run git pull the directory remains empty..
What I did now is: copy the ts files from another QGIS repository into the
"master" repository (the one I use to compile QGIS). Edit the transifexrc
file and re-running ./script(pull_ts.sh
After a while I receive this error:
Updating python translations
Can't locate XML/Simple.pm in @INC (you may need to install the XML::Simple
module) (@INC contains: /etc/perl /usr/local/lib/i386-linux-gnu/perl/5.20.1
/usr/local/share/perl/5.20.1 /usr/lib/i386-linux-gnu/perl5/5.20
/usr/share/perl5 /usr/lib/i386-linux-gnu/perl/5.20 /usr/share/perl/5.20
/usr/local/lib/site_perl .) at ../scripts/ts2cpp.pl line 17.
BEGIN failed--compilation aborted at ../scripts/ts2cpp.pl line 17.
And a last question.. I have to run first script/pull_ts.sh and then
compile QGIS in order to see the changes, right? Or can I have QGIS
compiled and script/pull_ts.sh updates the translations anyway?!
Thanks guys
Matteo
2015-02-18 15:58 GMT+01:00 Werner Macho <werner.macho at gmail.com>:
> Hi!
> Never had this type of error ..
> Are you sure you executed the pull_ts.sh script from the root
> directory of a git cloned repository?
> ./scripts/pull_ts.sh
> otherwise I have no clue what could have happened.. can you join into
> the i18n dir and take a look whats inside?
> regards
> Werner
> On Wed, Feb 18, 2015 at 3:18 PM, Matteo Ghetta <matteo.ghetta at gmail.com>
> wrote:
> > Hi Werner,
> > thanks for the reply.
> > I have now tx-client installed on my pc, but still problem when running
> > ./script/pull_ts.sh
> > Saving translations
> > rm: cannot remove ‘i18n/qgis_*.ts’: No such file or directory
> > Restoring files...
> > no idea how to fix this...
> > Thanks
> > Matteo
> > 2015-02-18 10:19 GMT+01:00 Werner Macho <werner.macho at gmail.com>:
> >> Hi Matteo.
> >> Doing the
> >> is the correct way - but the message
> >> tx not found only indicates that you are missing the (python) transifex
> >> client
> >> which can be installed as
> >> pip install transifex-client
> >> IIRC
> >> hope this helps
> >> kind regards
> >> Werner
> >> On Wed, Feb 18, 2015 at 10:13 AM, Matteo Ghetta <
> >> wrote:
> >> > Hi all,
> >> > I have a simple question, but I cannot deal with this issue.
> >> > I'm compiling QGIS, but what should I do in order to update also the
> >> > translation?
> >> > I tried:
> >> > ./pull_ts.sh
> >> > inside the scripts dir, but I got an error:
> >> > ./pull_ts.sh: line 18: scripts/update_ts.sh: No such file or directory
> >> > so I tried
> >> > in the main dir of the repo, but I got
> >> > tx not found
> >> > Am I missing something?
> >> > Thanks to all
> >> > Matteo
> >> > _______________________________________________
> >> > Qgis-tr mailing list
> >> > Qgis-tr at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20150218/cfc55c2b/attachment-0001.html>
More information about the Qgis-tr mailing list
