[Qgis-tr] update the language when compiling QGIS
Werner Macho werner.macho at gmail.com
Wed Feb 18 07:41:55 PST 2015
Hi Matteo,
The answers in short:
The error is from a missing perl module
http://search.cpan.org/~grantm/XML-Simple-2.20/lib/XML/Simple.pm
don't ask me why it needs this perl module - I never had this problem before ..
Usually there is a package with a name similar to libxml-simple-perl
(this is the name in debian)
the second thing is that you have to configure your tx client first
using your transifex credentials before you are able to "login" and
pull:
http://docs.transifex.com/developer/client/config
hope this helps
regards
Werner
On Wed, Feb 18, 2015 at 4:28 PM, Matteo Ghetta <matteo.ghetta at gmail.com> wrote:
> it seems that after running for the first time ./script/pull_ts.sh all the
> .ts files inside i18t have been deleted due to:
> ./script/pull_ts.sh
> Pulling new translations...
> Exception: No user credentials found for host https://www.transifex.com.
> Edit ~/.transifexrc and add the appropriate info in there.
> Restoring files...
> Removing temporary files
> weird (for me) is that if I run git pull the directory remains empty..
> What I did now is: copy the ts files from another QGIS repository into the
> "master" repository (the one I use to compile QGIS). Edit the transifexrc
> file and re-running ./script(pull_ts.sh
> After a while I receive this error:
> Updating python translations
> Can't locate XML/Simple.pm in @INC (you may need to install the XML::Simple
> module) (@INC contains: /etc/perl /usr/local/lib/i386-linux-gnu/perl/5.20.1
> /usr/local/share/perl/5.20.1 /usr/lib/i386-linux-gnu/perl5/5.20
> /usr/share/perl5 /usr/lib/i386-linux-gnu/perl/5.20 /usr/share/perl/5.20
> /usr/local/lib/site_perl .) at ../scripts/ts2cpp.pl line 17.
> BEGIN failed--compilation aborted at ../scripts/ts2cpp.pl line 17.
> And a last question.. I have to run first script/pull_ts.sh and then compile
> QGIS in order to see the changes, right? Or can I have QGIS compiled and
> script/pull_ts.sh updates the translations anyway?!
> Thanks guys
> Matteo
> 2015-02-18 15:58 GMT+01:00 Werner Macho <werner.macho at gmail.com>:
>> Hi!
>> Never had this type of error ..
>> Are you sure you executed the pull_ts.sh script from the root
>> directory of a git cloned repository?
>> ./scripts/pull_ts.sh
>> otherwise I have no clue what could have happened.. can you join into
>> the i18n dir and take a look whats inside?
>> regards
>> Werner
>> On Wed, Feb 18, 2015 at 3:18 PM, Matteo Ghetta <matteo.ghetta at gmail.com>
>> wrote:
>> > Hi Werner,
>> > thanks for the reply.
>> > I have now tx-client installed on my pc, but still problem when running
>> > ./script/pull_ts.sh
>> > Saving translations
>> > rm: cannot remove ‘i18n/qgis_*.ts’: No such file or directory
>> > Restoring files...
>> > no idea how to fix this...
>> > Thanks
>> > Matteo
>> > 2015-02-18 10:19 GMT+01:00 Werner Macho <werner.macho at gmail.com>:
>> >> Hi Matteo.
>> >> Doing the
>> >> is the correct way - but the message
>> >> tx not found only indicates that you are missing the (python) transifex
>> >> client
>> >> which can be installed as
>> >> pip install transifex-client
>> >> IIRC
>> >> hope this helps
>> >> kind regards
>> >> Werner
>> >> On Wed, Feb 18, 2015 at 10:13 AM, Matteo Ghetta
>> >> wrote:
>> >> > Hi all,
>> >> > I have a simple question, but I cannot deal with this issue.
>> >> > I'm compiling QGIS, but what should I do in order to update also the
>> >> > translation?
>> >> > I tried:
>> >> > ./pull_ts.sh
>> >> > inside the scripts dir, but I got an error:
>> >> > ./pull_ts.sh: line 18: scripts/update_ts.sh: No such file or
>> >> > directory
>> >> > so I tried
>> >> > in the main dir of the repo, but I got
>> >> > tx not found
>> >> > Am I missing something?
>> >> > Thanks to all
>> >> > Matteo
>> >> > _______________________________________________
>> >> > Qgis-tr mailing list
>> >> > Qgis-tr at lists.osgeo.org
>> >> > http://lists.osgeo.org/mailman/listinfo/qgis-tr
More information about the Qgis-tr mailing list
