[Qgis-tr] update the language when compiling QGIS
Matteo Ghetta matteo.ghetta at gmail.com
Wed Feb 18 07:48:56 PST 2015
HI Werner,
sorry to keep you asking things..
module installed and client configured... other error... :(
Saving translations
tar: src/plugins/plugin_template/plugingui.cpp: Cannot stat: No such file
or directory
tar: src/plugins/plugin_template/plugin.cpp: Cannot stat: No such file or
directory
tar: Exiting with failure status due to previous errors
Restoring files...
Removing temporary files
what is wrong with plugins?!?
2015-02-18 16:41 GMT+01:00 Werner Macho <werner.macho at gmail.com>:
> Hi Matteo,
> The answers in short:
> The error is from a missing perl module
> http://search.cpan.org/~grantm/XML-Simple-2.20/lib/XML/Simple.pm
> don't ask me why it needs this perl module - I never had this problem
> before ..
> Usually there is a package with a name similar to libxml-simple-perl
> (this is the name in debian)
> the second thing is that you have to configure your tx client first
> using your transifex credentials before you are able to "login" and
> pull:
> http://docs.transifex.com/developer/client/config
> hope this helps
> regards
> Werner
> On Wed, Feb 18, 2015 at 4:28 PM, Matteo Ghetta <matteo.ghetta at gmail.com>
> wrote:
> > it seems that after running for the first time ./script/pull_ts.sh all
> the
> > .ts files inside i18t have been deleted due to:
> > ./script/pull_ts.sh
> > Pulling new translations...
> > Exception: No user credentials found for host https://www.transifex.com.
> > Edit ~/.transifexrc and add the appropriate info in there.
> > Restoring files...
> > weird (for me) is that if I run git pull the directory remains empty..
> > What I did now is: copy the ts files from another QGIS repository into
> the
> > "master" repository (the one I use to compile QGIS). Edit the transifexrc
> > file and re-running ./script(pull_ts.sh
> > After a while I receive this error:
> > Updating python translations
> > Can't locate XML/Simple.pm in @INC (you may need to install the
> XML::Simple
> > module) (@INC contains: /etc/perl
> /usr/local/lib/i386-linux-gnu/perl/5.20.1
> > /usr/local/share/perl/5.20.1 /usr/lib/i386-linux-gnu/perl5/5.20
> > /usr/share/perl5 /usr/lib/i386-linux-gnu/perl/5.20 /usr/share/perl/5.20
> > /usr/local/lib/site_perl .) at ../scripts/ts2cpp.pl line 17.
> > BEGIN failed--compilation aborted at ../scripts/ts2cpp.pl line 17.
> > And a last question.. I have to run first script/pull_ts.sh and then
> compile
> > QGIS in order to see the changes, right? Or can I have QGIS compiled and
> > script/pull_ts.sh updates the translations anyway?!
> > Thanks guys
> > Matteo
> > 2015-02-18 15:58 GMT+01:00 Werner Macho <werner.macho at gmail.com>:
> >> Hi!
> >> Never had this type of error ..
> >> Are you sure you executed the pull_ts.sh script from the root
> >> directory of a git cloned repository?
> >> ./scripts/pull_ts.sh
> >> otherwise I have no clue what could have happened.. can you join into
> >> the i18n dir and take a look whats inside?
> >> regards
> >> Werner
> >> On Wed, Feb 18, 2015 at 3:18 PM, Matteo Ghetta <matteo.ghetta at gmail.com
> >> wrote:
> >> > Hi Werner,
> >> > thanks for the reply.
> >> > I have now tx-client installed on my pc, but still problem when
> running
> >> > ./script/pull_ts.sh
> >> > Saving translations
> >> > rm: cannot remove ‘i18n/qgis_*.ts’: No such file or directory
> >> > Restoring files...
> >> > no idea how to fix this...
> >> > Thanks
> >> > Matteo
> >> > 2015-02-18 10:19 GMT+01:00 Werner Macho <werner.macho at gmail.com>:
> >> >> Hi Matteo.
> >> >> Doing the
> >> >> is the correct way - but the message
> >> >> tx not found only indicates that you are missing the (python)
> transifex
> >> >> client
> >> >> which can be installed as
> >> >> pip install transifex-client
> >> >> IIRC
> >> >> hope this helps
> >> >> kind regards
> >> >> Werner
> >> >> On Wed, Feb 18, 2015 at 10:13 AM, Matteo Ghetta
> >> >> wrote:
> >> >> > Hi all,
> >> >> > I have a simple question, but I cannot deal with this issue.
> >> >> > I'm compiling QGIS, but what should I do in order to update also
> the
> >> >> > translation?
> >> >> > I tried:
> >> >> > ./pull_ts.sh
> >> >> > inside the scripts dir, but I got an error:
> >> >> > ./pull_ts.sh: line 18: scripts/update_ts.sh: No such file or
> >> >> > directory
> >> >> > so I tried
> >> >> > in the main dir of the repo, but I got
> >> >> > tx not found
> >> >> > Am I missing something?
> >> >> > Thanks to all
> >> >> > Matteo
> >> >> > _______________________________________________
> >> >> > Qgis-tr mailing list
> >> >> > Qgis-tr at lists.osgeo.org
> >> >> > http://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20150218/28025e9d/attachment.html>
More information about the Qgis-tr mailing list
