[Qgis-tr] update the language when compiling QGIS
Werner Macho werner.macho at gmail.com
Wed Feb 18 07:55:07 PST 2015
hi!
now I am out of ideas..
Are you really sure you are on a FULL clean clone/checkout of QGIS
source directory?
According to
https://github.com/qgis/QGIS/tree/master/src/plugins/plugin_template
you should have these files - I don't know why they are missing with your clone.
regards
Werner
On Wed, Feb 18, 2015 at 4:48 PM, Matteo Ghetta <matteo.ghetta at gmail.com> wrote:
> HI Werner,
> sorry to keep you asking things..
> module installed and client configured... other error... :(
> Saving translations
> tar: src/plugins/plugin_template/plugingui.cpp: Cannot stat: No such file or
> directory
> tar: src/plugins/plugin_template/plugin.cpp: Cannot stat: No such file or
> directory
> tar: Exiting with failure status due to previous errors
> Restoring files...
> Removing temporary files
> what is wrong with plugins?!?
> 2015-02-18 16:41 GMT+01:00 Werner Macho <werner.macho at gmail.com>:
>> Hi Matteo,
>> The answers in short:
>> The error is from a missing perl module
>> http://search.cpan.org/~grantm/XML-Simple-2.20/lib/XML/Simple.pm
>> don't ask me why it needs this perl module - I never had this problem
>> before ..
>> Usually there is a package with a name similar to libxml-simple-perl
>> (this is the name in debian)
>> the second thing is that you have to configure your tx client first
>> using your transifex credentials before you are able to "login" and
>> pull:
>> http://docs.transifex.com/developer/client/config
>> hope this helps
>> regards
>> Werner
>> On Wed, Feb 18, 2015 at 4:28 PM, Matteo Ghetta <matteo.ghetta at gmail.com>
>> wrote:
>> > it seems that after running for the first time ./script/pull_ts.sh all
>> > the
>> > .ts files inside i18t have been deleted due to:
>> > ./script/pull_ts.sh
>> > Pulling new translations...
>> > Exception: No user credentials found for host https://www.transifex.com.
>> > Edit ~/.transifexrc and add the appropriate info in there.
>> > Restoring files...
>> > weird (for me) is that if I run git pull the directory remains empty..
>> > What I did now is: copy the ts files from another QGIS repository into
>> > the
>> > "master" repository (the one I use to compile QGIS). Edit the
>> > transifexrc
>> > file and re-running ./script(pull_ts.sh
>> > After a while I receive this error:
>> > Updating python translations
>> > Can't locate XML/Simple.pm in @INC (you may need to install the
>> > XML::Simple
>> > module) (@INC contains: /etc/perl
>> > /usr/local/lib/i386-linux-gnu/perl/5.20.1
>> > /usr/local/share/perl/5.20.1 /usr/lib/i386-linux-gnu/perl5/5.20
>> > /usr/share/perl5 /usr/lib/i386-linux-gnu/perl/5.20 /usr/share/perl/5.20
>> > /usr/local/lib/site_perl .) at ../scripts/ts2cpp.pl line 17.
>> > BEGIN failed--compilation aborted at ../scripts/ts2cpp.pl line 17.
>> > And a last question.. I have to run first script/pull_ts.sh and then
>> > compile
>> > QGIS in order to see the changes, right? Or can I have QGIS compiled and
>> > script/pull_ts.sh updates the translations anyway?!
>> > Thanks guys
>> > Matteo
>> > 2015-02-18 15:58 GMT+01:00 Werner Macho <werner.macho at gmail.com>:
>> >> Hi!
>> >> Never had this type of error ..
>> >> Are you sure you executed the pull_ts.sh script from the root
>> >> directory of a git cloned repository?
>> >> ./scripts/pull_ts.sh
>> >> otherwise I have no clue what could have happened.. can you join into
>> >> the i18n dir and take a look whats inside?
>> >> regards
>> >> Werner
>> >> On Wed, Feb 18, 2015 at 3:18 PM, Matteo Ghetta
>> >> wrote:
>> >> > Hi Werner,
>> >> > thanks for the reply.
>> >> > I have now tx-client installed on my pc, but still problem when
>> >> > running
>> >> > ./script/pull_ts.sh
>> >> > Saving translations
>> >> > rm: cannot remove ‘i18n/qgis_*.ts’: No such file or directory
>> >> > Restoring files...
>> >> > no idea how to fix this...
>> >> > Thanks
>> >> > Matteo
>> >> > 2015-02-18 10:19 GMT+01:00 Werner Macho <werner.macho at gmail.com>:
>> >> >> Hi Matteo.
>> >> >> Doing the
>> >> >> is the correct way - but the message
>> >> >> tx not found only indicates that you are missing the (python)
>> >> >> transifex
>> >> >> client
>> >> >> which can be installed as
>> >> >> pip install transifex-client
>> >> >> IIRC
>> >> >> hope this helps
>> >> >> kind regards
>> >> >> Werner
>> >> >> On Wed, Feb 18, 2015 at 10:13 AM, Matteo Ghetta
>> >> >> wrote:
>> >> >> > Hi all,
>> >> >> > I have a simple question, but I cannot deal with this issue.
>> >> >> > I'm compiling QGIS, but what should I do in order to update also
>> >> >> > the
>> >> >> > translation?
>> >> >> > I tried:
>> >> >> > ./pull_ts.sh
>> >> >> > inside the scripts dir, but I got an error:
>> >> >> > ./pull_ts.sh: line 18: scripts/update_ts.sh: No such file or
>> >> >> > directory
>> >> >> > so I tried
>> >> >> > in the main dir of the repo, but I got
>> >> >> > tx not found
>> >> >> > Am I missing something?
>> >> >> > Thanks to all
>> >> >> > Matteo
>> >> >> > _______________________________________________
>> >> >> > Qgis-tr mailing list
>> >> >> > Qgis-tr at lists.osgeo.org
>> >> >> > http://lists.osgeo.org/mailman/listinfo/qgis-tr
More information about the Qgis-tr mailing list
