[Qgis-tr] update the language when compiling QGIS
Matteo Ghetta matteo.ghetta at gmail.com
Wed Feb 18 08:27:12 PST 2015
I neither have any idea of what's going on with my clone..
Shouldn't git pull update the master branch of github with my clone?
It says: already updated..
2015-02-18 16:55 GMT+01:00 Werner Macho <werner.macho at gmail.com>:
> hi!
> now I am out of ideas..
> Are you really sure you are on a FULL clean clone/checkout of QGIS
> source directory?
> According to
> https://github.com/qgis/QGIS/tree/master/src/plugins/plugin_template
> you should have these files - I don't know why they are missing with your
> clone.
> regards
> Werner
> On Wed, Feb 18, 2015 at 4:48 PM, Matteo Ghetta <matteo.ghetta at gmail.com>
> wrote:
> > HI Werner,
> > sorry to keep you asking things..
> > module installed and client configured... other error... :(
> > Saving translations
> > tar: src/plugins/plugin_template/plugingui.cpp: Cannot stat: No such
> file or
> > directory
> > tar: src/plugins/plugin_template/plugin.cpp: Cannot stat: No such file or
> > directory
> > tar: Exiting with failure status due to previous errors
> > Restoring files...
> > Removing temporary files
> > what is wrong with plugins?!?
> > 2015-02-18 16:41 GMT+01:00 Werner Macho <werner.macho at gmail.com>:
> >> Hi Matteo,
> >> The answers in short:
> >> The error is from a missing perl module
> >> http://search.cpan.org/~grantm/XML-Simple-2.20/lib/XML/Simple.pm
> >> don't ask me why it needs this perl module - I never had this problem
> >> before ..
> >> Usually there is a package with a name similar to libxml-simple-perl
> >> (this is the name in debian)
> >> the second thing is that you have to configure your tx client first
> >> using your transifex credentials before you are able to "login" and
> >> pull:
> >> http://docs.transifex.com/developer/client/config
> >> hope this helps
> >> regards
> >> Werner
> >> On Wed, Feb 18, 2015 at 4:28 PM, Matteo Ghetta <matteo.ghetta at gmail.com
> >> wrote:
> >> > it seems that after running for the first time ./script/pull_ts.sh all
> >> > the
> >> > .ts files inside i18t have been deleted due to:
> >> > ./script/pull_ts.sh
> >> > Pulling new translations...
> >> > Exception: No user credentials found for host
> https://www.transifex.com.
> >> > Edit ~/.transifexrc and add the appropriate info in there.
> >> > Restoring files...
> >> > weird (for me) is that if I run git pull the directory remains empty..
> >> > What I did now is: copy the ts files from another QGIS repository into
> >> > the
> >> > "master" repository (the one I use to compile QGIS). Edit the
> >> > transifexrc
> >> > file and re-running ./script(pull_ts.sh
> >> > After a while I receive this error:
> >> > Updating python translations
> >> > Can't locate XML/Simple.pm in @INC (you may need to install the
> >> > XML::Simple
> >> > module) (@INC contains: /etc/perl
> >> > /usr/local/lib/i386-linux-gnu/perl/5.20.1
> >> > /usr/local/share/perl/5.20.1 /usr/lib/i386-linux-gnu/perl5/5.20
> >> > /usr/share/perl5 /usr/lib/i386-linux-gnu/perl/5.20
> /usr/share/perl/5.20
> >> > /usr/local/lib/site_perl .) at ../scripts/ts2cpp.pl line 17.
> >> > BEGIN failed--compilation aborted at ../scripts/ts2cpp.pl line 17.
> >> > And a last question.. I have to run first script/pull_ts.sh and then
> >> > compile
> >> > QGIS in order to see the changes, right? Or can I have QGIS compiled
> and
> >> > script/pull_ts.sh updates the translations anyway?!
> >> > Thanks guys
> >> > Matteo
> >> > 2015-02-18 15:58 GMT+01:00 Werner Macho <werner.macho at gmail.com>:
> >> >> Hi!
> >> >> Never had this type of error ..
> >> >> Are you sure you executed the pull_ts.sh script from the root
> >> >> directory of a git cloned repository?
> >> >> ./scripts/pull_ts.sh
> >> >> otherwise I have no clue what could have happened.. can you join into
> >> >> the i18n dir and take a look whats inside?
> >> >> regards
> >> >> Werner
> >> >> On Wed, Feb 18, 2015 at 3:18 PM, Matteo Ghetta
> >> >> wrote:
> >> >> > Hi Werner,
> >> >> > thanks for the reply.
> >> >> > I have now tx-client installed on my pc, but still problem when
> >> >> > running
> >> >> > ./script/pull_ts.sh
> >> >> > Saving translations
> >> >> > rm: cannot remove ‘i18n/qgis_*.ts’: No such file or directory
> >> >> > Restoring files...
> >> >> > no idea how to fix this...
> >> >> > Thanks
> >> >> > Matteo
> >> >> > 2015-02-18 10:19 GMT+01:00 Werner Macho <werner.macho at gmail.com>:
> >> >> >> Hi Matteo.
> >> >> >> Doing the
> >> >> >> is the correct way - but the message
> >> >> >> tx not found only indicates that you are missing the (python)
> >> >> >> transifex
> >> >> >> client
> >> >> >> which can be installed as
> >> >> >> pip install transifex-client
> >> >> >> IIRC
> >> >> >> hope this helps
> >> >> >> kind regards
> >> >> >> Werner
> >> >> >> On Wed, Feb 18, 2015 at 10:13 AM, Matteo Ghetta
> >> >> >> wrote:
> >> >> >> > Hi all,
> >> >> >> > I have a simple question, but I cannot deal with this issue.
> >> >> >> > I'm compiling QGIS, but what should I do in order to update also
> >> >> >> > the
> >> >> >> > translation?
> >> >> >> > I tried:
> >> >> >> > ./pull_ts.sh
> >> >> >> > inside the scripts dir, but I got an error:
> >> >> >> > ./pull_ts.sh: line 18: scripts/update_ts.sh: No such file or
> >> >> >> > directory
> >> >> >> > so I tried
> >> >> >> > in the main dir of the repo, but I got
> >> >> >> > tx not found
> >> >> >> > Am I missing something?
> >> >> >> > Thanks to all
> >> >> >> > Matteo
> >> >> >> > _______________________________________________
> >> >> >> > Qgis-tr mailing list
> >> >> >> > Qgis-tr at lists.osgeo.org
> >> >> >> > http://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20150218/0886fa28/attachment.html>
More information about the Qgis-tr mailing list
