[Qgis-tr] update the language when compiling QGIS
Werner Macho werner.macho at gmail.com
Wed Feb 18 09:00:28 PST 2015
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi!
The only thing that I can think of now is
git reset --hard HEAD
though not sure if that will really work.
But if you cannot do anything afterwards with transifex you somehow
screwed up your clone.
HTH
regards
Werner
On 02/18/2015 05:27 PM, Matteo Ghetta wrote:
> I neither have any idea of what's going on with my clone..
> Shouldn't git pull update the master branch of github with my
> clone?
> It says: already updated..
> 2015-02-18 16:55 GMT+01:00 Werner Macho <werner.macho at gmail.com
> <mailto:werner.macho at gmail.com>>:
> hi! now I am out of ideas.. Are you really sure you are on a FULL
> clean clone/checkout of QGIS source directory? According to
> https://github.com/qgis/QGIS/tree/master/src/plugins/plugin_template
you should have these files - I don't know why they are missing with
> your clone.
> regards Werner
> On Wed, Feb 18, 2015 at 4:48 PM, Matteo Ghetta
> <matteo.ghetta at gmail.com <mailto:matteo.ghetta at gmail.com>> wrote:
>> HI Werner, sorry to keep you asking things.. module installed and
>> client configured... other error... :(
>> Saving translations tar:
>> src/plugins/plugin_template/plugingui.cpp: Cannot stat: No
> such file or
>> directory tar: src/plugins/plugin_template/plugin.cpp: Cannot
>> stat: No such
> file or
>> directory tar: Exiting with failure status due to previous
>> errors Restoring files... Removing temporary files
>> what is wrong with plugins?!?
>> 2015-02-18 16:41 GMT+01:00 Werner Macho <werner.macho at gmail.com
>>> Hi Matteo,
>>> The answers in short:
>>> The error is from a missing perl module
>>> http://search.cpan.org/~grantm/XML-Simple-2.20/lib/XML/Simple.pm
>> don't ask me why it needs this perl module - I never had this
>> problem
>>> before .. Usually there is a package with a name similar to
>>> libxml-simple-perl (this is the name in debian)
>>> the second thing is that you have to configure your tx client
>>> first using your transifex credentials before you are able to
>>> "login" and pull:
>>> http://docs.transifex.com/developer/client/config
>>> hope this helps regards Werner
>>> On Wed, Feb 18, 2015 at 4:28 PM, Matteo Ghetta
>>> wrote:
>>>> it seems that after running for the first time
> ./script/pull_ts.sh all
>>>> the .ts files inside i18t have been deleted due to:
>>>> ./script/pull_ts.sh Pulling new translations... Exception: No
>>>> user credentials found for host
> https://www.transifex.com.
>>>> Edit ~/.transifexrc and add the appropriate info in there.
>>>> weird (for me) is that if I run git pull the directory
>>>> remains
> empty..
>>>> What I did now is: copy the ts files from another QGIS
> repository into
>>>> the "master" repository (the one I use to compile QGIS). Edit
>>>> the transifexrc file and re-running ./script(pull_ts.sh
>>>> After a while I receive this error: Updating python
>>>> translations Can't locate XML/Simple.pm in @INC (you may need
>>>> to install the XML::Simple module) (@INC contains: /etc/perl
>>>> /usr/local/lib/i386-linux-gnu/perl/5.20.1
>>>> /usr/local/share/perl/5.20.1
>>>> /usr/lib/i386-linux-gnu/perl5/5.20 /usr/share/perl5
>>>> /usr/lib/i386-linux-gnu/perl/5.20
> /usr/share/perl/5.20
>>>> /usr/local/lib/site_perl .) at ../scripts/ts2cpp.pl
> <http://ts2cpp.pl> line 17.
>>>> BEGIN failed--compilation aborted at ../scripts/ts2cpp.pl
>>>> And a last question.. I have to run first script/pull_ts.sh
>>>> and
> then
>>>> compile QGIS in order to see the changes, right? Or can I
>>>> have QGIS
> compiled and
>>>> script/pull_ts.sh updates the translations anyway?!
>>>> Thanks guys
>>>> Matteo
>>>> 2015-02-18 15:58 GMT+01:00 Werner Macho
>>>>> Hi!
>>>>> Never had this type of error .. Are you sure you executed
>>>>> the pull_ts.sh script from the root directory of a git
>>>>> cloned repository?
>>>>> ./scripts/pull_ts.sh
>>>>> otherwise I have no clue what could have happened.. can
>>>>> you
> join into
>>>>> the i18n dir and take a look whats inside?
>>>>> regards Werner
>>>>> On Wed, Feb 18, 2015 at 3:18 PM, Matteo Ghetta
>>>>> wrote:
>>>>>> Hi Werner, thanks for the reply. I have now tx-client
>>>>>> installed on my pc, but still problem when running
>>>>>> ./script/pull_ts.sh
>>>>>> Saving translations rm: cannot remove ‘i18n/qgis_*.ts’:
>>>>>> No such file or directory Restoring files... Removing
>>>>>> temporary files
>>>>>> no idea how to fix this...
>>>>>> Thanks
>>>>>> Matteo
>>>>>> 2015-02-18 10:19 GMT+01:00 Werner Macho
> <werner.macho at gmail.com <mailto:werner.macho at gmail.com>>:
>>>>>>> Hi Matteo.
>>>>>>> Doing the
>>>>>>> is the correct way - but the message tx not found only
>>>>>>> indicates that you are missing the (python) transifex
>>>>>>> client
>>>>>>> which can be installed as pip install transifex-client
>>>>>>> IIRC
>>>>>>> hope this helps kind regards Werner
>>>>>>> On Wed, Feb 18, 2015 at 10:13 AM, Matteo Ghetta
>>>>>>>> Hi all, I have a simple question, but I cannot deal
>>>>>>>> with this issue. I'm compiling QGIS, but what should
>>>>>>>> I do in order to
> update also
>>>>>>>> the translation? I tried:
>>>>>>>> ./pull_ts.sh
>>>>>>>> inside the scripts dir, but I got an error:
>>>>>>>> ./pull_ts.sh: line 18: scripts/update_ts.sh: No such
>>>>>>>> file or directory
>>>>>>>> so I tried
>>>>>>>> in the main dir of the repo, but I got
>>>>>>>> tx not found
>>>>>>>> Am I missing something?
>>>>>>>> Thanks to all
>>>>>>>> Matteo
>>>>>>>> _______________________________________________
>>>>>>>> Qgis-tr mailing list Qgis-tr at lists.osgeo.org
>>>>>>>> <mailto:Qgis-tr at lists.osgeo.org>
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-tr
>>>>>>> _______________________________________________ Qgis-tr
>>> _______________________________________________ Qgis-tr mailing
>>> list Qgis-tr at lists.osgeo.org <mailto:Qgis-tr at lists.osgeo.org>
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.15 (GNU/Linux)
iEYEARECAAYFAlTkxSkACgkQDAH1YiCxBgmedQCfegE/oVEEutpPweivFamQQysS
xtoAn3XjlkD4gsAGmdALi8kI08l+0FPH
=zlH0
-----END PGP SIGNATURE-----
More information about the Qgis-tr mailing list
