[Qgis-tr] Are Transifex translations going anywhere?
Carlos Dávila cdavilam at orangecorreo.es
Wed Apr 20 00:08:32 PDT 2016
El 20/04/16 a las 08:50, Richard Duivenvoorde escribió:
> Transifex Webtranslation page for QGIS is on https://www.transifex.com/qgis/
> On 20-04-16 00:16, Jürgen E. Fischer wrote:
>> Hi Carlos,
>> On Tue, 19. Apr 2016 at 18:06:14 +0200, Carlos Dávila wrote:
>>> In the last days I've been working on the Spanish translation of
>>> QGIS Desktop on Transifex, but I don't see my changes neither in
>>> master nor in 2.14 branch of github. Is there something broken in
>>> the process of updating translations?
>> No.  Translations are pulled in on release.  You can run scripts/pull_ts.sh to
>> pull translations from transifex into local builds (like it's done in the
>> nightlies).
> So (see frontpage right top of qgis.org): next point release 2.14.2
> (2.8.9??) will be 29th of april, THEN you should see the fresh translations.
> And as Jürgen says: if you install QGIS via osgeo4w (if on Windows) it
> is easy to check the nightlies every day. And if you are on Linux:
> really it is not as difficult as it looks to compile from source...
> Regards,
> Richard
I usually compile QGIS from source on debian Linux to test translations.
In the past it wasn't necessary to manually pull translations, they were
updated with the rest of the code. I've tried scripts/pull_ts.sh, but
first I had to change pylupdate4 by pylupdate5 and next "tx not found"
error stops the script. Could you point me to the package containing tx?
I could not find it.
More information about the Qgis-tr mailing list
