[Qgis-tr] Typo in qgis-application .ts-file
Sveinn í Felli sv1 at fellsnet.is
Tue Nov 15 01:49:27 PST 2016
Agree, those shortcuts are not that urgent; it's not like everybody is
modifying their program options every 2 minutes ;-)
But when you have shortcuts like these, logically they should be on all
three options.
Unless the logic is that one of the options is a default one, and there
are shortcuts on the *other* items...
Maybe these are simply redundant.
Best,
Sveinn
Þann þri 15.nóv 2016 09:30, skrifaði Werner Macho:
> Transifex Webtranslation page for QGIS is on https://www.transifex.com/qgis/
> Hi and thanks for the report!
> I am going to correct it this evening (once I am back home from work).
> The thing with the shortcuts is always:
> 1. Is the same shortcut key already existing somewhere else (-> conflict)
> 2. Is a shortcut key really necessary at this place?
> So I think at some point an overview about (default) shortcuts would
> be nice to not assign them twice .. and I think its not necessary to
> have a shortcut everywhere..
> regards
> Werner
> On Tue, Nov 15, 2016 at 9:40 AM, Sveinn í Felli <sv1 at fellsnet.is> wrote:
>> Some spelling/typographic/shortcut errors in source:
>> (line#: ~10582)
>>         <message>
>>             <source>Highlight Pinned Labels And DIagrams</source>
>> "DIagrams" should be "Diagrams"
>> In Options->CRS tab there are three (radio-button) options under the first
>> section "Default CRS for new projects":
>>    "Don't enable 'on the fly' reprojection"
>>    "Automatically enable 'on the fly' reprojection if layers ha&ve different
>> CRS"
>>    "Enable 'on the &fly' reprojection by default"
>> The first one is missing a &shortcut key.
>> The next section in this tab is also a bit curious, "CRS for new layers"
>> also has three options and the third one is missing a shortcut key:
>>    "Pro&mpt for CRS"
>>    "Use pro&ject CRS"
>>    "Use a default CRS" + dropdown selection
>> Is there a logic for the last one not to have a shortcut key ?
>> Hope someone here is in position to explain or correct these.
>> Best regards,
>> Sveinn í Felli
>> QGIS-Translators mailing list
>> Qgis-tr at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-tr
More information about the Qgis-tr mailing list
