[Qgis-tr] Impossible to translate a string
Dick Groskamp dikgro at yahoo.co.uk
Fri Sep 1 08:09:11 PDT 2017
Stefano,
it has probably to do with the number of translations.Yhere should probably be two:
one for a singel object
one voor multiple objects
The reason why it is noy savinf is that youy have not filled one of the two possibilities""Fill in all plurals to continue"
In the upper right corner of the translation pane of Transifexit syas  [1]  [other]
Clicking  [1] or [other]  switches between the two options
If both options are filled you can save the translation
__________
DiGro
      Van: Stefano Campus <skampus at gmail.com>
 Aan: qgis-tr at lists.osgeo.org
 Verzonden: vrijdag 1 september 15:04 2017
 Onderwerp: [Qgis-tr] Impossible to translate a string
Hi, I'm trying to translate this string of QGIS-application in italian, but Transifex tells that there is an error in the original english phrase
ERROR: %n feature(s) not added - geometry type is not compatible with the current layer.
it's not possible to save a translation "Fill in all plurals to continue".
I'm translating from English to Italian. Is there any other language which has same problem?
thank you
stefanoTransifex Webtranslation page for QGIS is on https://www.transifex.com/qgis/
QGIS-Translators mailing list
Qgis-tr at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20170901/d6d517ea/attachment.html>
More information about the Qgis-tr mailing list
