[Qgis-tr] [QGIS-Developer] Missing translated strings in localized master
Borys Jurgiel lists at borysjurgiel.pl
Fri Oct 26 03:07:37 PDT 2018
The source code in git contains very outdated ts files, and you need to
explicitly pull the translations from Transifex before compiling (it's what
e.g. the nightly build script does every time).
There is the scripts/update_ts.sh script, or you can simply run the only
important line from it:
tx pull -f -l it
(where it is the language code)
You'll need the tx (Transifex client) installed and api key configured, so for
a quick test you can just download the ts file from Transifex web page and
replace it manually in your source tree.
Hopefully it is the reason.
Borys
PS. Seems I'm getting old. No swear word in a whole mail about Transifex...
Dnia piątek, 26 października 2018 11:42:56 CEST matteo pisze:
> Hi Borys,
> I'm afraid your workaround is not working for me. I reset the Processing
> menu to default but still the old (wrong) Italian translation is there.
> What I really don't understand is that in Transifex the corrected
> translation is there since 3 months (info of tx history tab), but for
> some strange reason, even if I have a new QGIS compiled from source, the
> old wrong translation is taken into account.
> Should I provide more information?
> Cheers and thanks
> Matteo
More information about the Qgis-tr mailing list
