[Qgis-tr] Suggestions available
Richard Duivenvoorde rdmailings at duif.net
Mon May 9 02:25:49 PDT 2022
I'd be fine what you propose, let me know if you need something.
Note that
  2. reactivate the zzz 3.16 project, fill it with 3.22 strings
is a hell of a job... as (I think) you need to upload for every language
every (translated) resource?
Or do you think there is a smarter solution?
Regards,
Richard
On 2022-05-09 11:16, DelazJ wrote:
> Transifex Webtranslation page for QGIS is on
> https://www.transifex.com/qgis/
> Hi Stefano, Alexandre
> Strings of the "zzz..." projects are available for the Desktop project
> because some time ago, Alexandre (I assumed he did because of [0]) put
> the projects altogether in what transifex calls a memory group [1]:
> they do share translations each other as suggestions.
> However, by the time we created the project for 3.22 documentation,
> that feature had become a paid one (ref the docs linked above), so
> that project is somehow isolated from the others. If you browse the
> QGIS Documentation project, you will notice that it provides
> suggestions from itself only. None of the other projects is connected
> to it, so you can't use translations you made in Desktop (or Website -
> though I'm not sure this one is connected) project.
> I'm still convinced that we should:
> 1. just drop the zzz projects (at least for 3.4 and 3.10). I'm
> honestly not convinced they are useful to anything today.
> 2. reactivate the zzz 3.16 project, fill it with 3.22 strings (source
> and translations) and rename it into QGIS Documentation. Would that
> fix Stefano's request ? I can't tell without testing because Transifex
> is a closed source project, but if we assume that what are referenced
> in the memory group foreign key is projects ID and not the strings or
> files of a named project, then reusing that project should work IMHO
> 3. Kill the current "QGIS Documentation" as its contents are moved to
> point 2. --> That would mean we have a single project for
> documentation also (along with Website and Desktop), clearer for
> everyone
> 4. Next time we release a docs project (3.28), we push strings in the
> "QGIS Documentation" project directly instead of creating a new
> project. Why did we not do it the last time? Because the previous
> experience using automated pull/push of Transifex<->github connection
> has been laborious and I was afraid I'd break something. The process
> is now "well" documented [2] with ways to recover if any problem.
> 5. If you are really really afraid that something breaks in 2/3, the
> resurrection and testing can be done in the zzz 3.4 project instead of
> zzz 3.16...
> [0]
> https://lists.osgeo.org/pipermail/qgis-community-team/2022-March/006039.html
> [1] https://docs.transifex.com/translation-memory/sharing-tm
> [2] https://github.com/qgis/QGIS-Documentation#translating
> Regards,
> Harrissou
> Le lun. 9 mai 2022 à 08:16, Alexandre Neto <senhor.neto at gmail.com> a
> écrit :
>> That's something that comes from the  translation memory. If that
>> string have never been translated in the more recent versions it
>> will pick up suggestions from older ones. Which I think it's useful,
>> and allow us to keep some coherence between versions.
>> Don't think there's a way to bump more recent results to the top,
>> other that deleting the old resources permanently.
>> Alexandre Neto
>> A domingo, 8/05/2022, 16:55, Stefano Campus <skampus at gmail.com>
>> escreveu:
>>> Hi, I noticed that while I'm translating in Transifex QGIS Desktop
>>> in the three versions (Master, 3.22 and 3.24), the available
>>> suggestions in the right window come from the desktop versions and
>>> from the "zzz OLD QGIS Documentation".
>>> the translation of the current and active version of the
>>> documentation is not proposed.
>>> How is it possible to make the suggestions of the Documentation
>>> project appear instead of those of the "zzz OLD" project?
>>> https://ibb.co/k9CMXd1
>>> https://ibb.co/SwfPMT6
>>> thank you and ciao!
>>> stefano _______________________________________________
>>> QGIS-Translators mailing list
>>> Qgis-tr at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/qgis-tr
More information about the Qgis-tr mailing list
