[Qgis-tr] Suggestions available
Alexandre Neto senhor.neto at gmail.com
Sat May 14 14:27:43 PDT 2022
Tricky situation...
Before any adventure, could we just ask transifex to add 3.22 to the
tranlaction memory group? They have offered some paid features before...
If not, let's do like Harrissou proposed and do some tests in 3.14 or 3.10
projects.
If we move to this single project idea, are there any caveats? We loose the
chance to keep translating older versions, but ... Is that something we
actually used? The translation memory will always be centered under the
same project, right?
Does it bring more work on every new release?
I can try to help in that work.
Alexandre Neto
A sábado, 14/05/2022, 12:27, Stefano Campus <skampus at gmail.com> escreveu:
> Transifex Webtranslation page for QGIS is on
> https://www.transifex.com/qgis/
> what surprises me is that the suggestions proposed are only those that
> come from zzz_Old_Documentation and never from QGSIS_documentation.
> do you think it can be done so that QGIS_documentation is linked to
> QGIS_Desktop, to have suggestions from both projects and thus make
> corrections for GUI and Documentation at the same time?
> thank you and ciao
> s.
> Il giorno lun 9 mag 2022 alle ore 08:16 Alexandre Neto <
>> That's something that comes from the  translation memory. If that string
>> have never been translated in the more recent versions it will pick up
>> suggestions from older ones. Which I think it's useful, and allow us to
>> keep some coherence between versions.
>> Don't think there's a way to bump more recent results to the top, other
>> that deleting the old resources permanently.
>> Alexandre Neto
>> A domingo, 8/05/2022, 16:55, Stefano Campus <skampus at gmail.com> escreveu:
>>> Hi, I noticed that while I'm translating in Transifex QGIS Desktop in
>>> the three versions (Master, 3.22 and 3.24), the available suggestions in
>>> the right window come from the desktop versions and from the "zzz OLD QGIS
>>> Documentation".
>>> the translation of the current and active version of the documentation
>>> is not proposed.
>>> How is it possible to make the suggestions of the Documentation project
>>> appear instead of those of the "zzz OLD" project?
>>> https://ibb.co/k9CMXd1
>>> https://ibb.co/SwfPMT6
>>> thank you and ciao!
>>> stefano
>>> QGIS-Translators mailing list
>>> Qgis-tr at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20220514/96dd3563/attachment.htm>
More information about the Qgis-tr mailing list
