[QGIS-trac] Re: [Quantum GIS] #1875: A few problems with crs definitions with TOWGS parameters
Quantum GIS qgis at qgis.org
Sun Aug 16 17:11:38 EDT 2009
        Reporter:  lutra                                      |         Owner:  homann
            Type:  bug                                        |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.2.0
       Component:  Projection Support                         |       Version:  HEAD
      Resolution:  fixed                                      |      Keywords:
Platform_version:                                             |      Platform:  All
        Must_fix:  No                                         |   Status_info:  0
Comment (by lutra):
 as you suggested I created two custom crs
 A) +proj=tmerc +lat_0=0 +lon_0=9 +k=0.9996 +x_0=1500000 +y_0=0 +ellps=intl
 +units=m +no_defs +datum=WGS84
 and
 B) +proj=tmerc +lat_0=0 +lon_0=9 +k=0.9996 +x_0=1500000 +y_0=0 +ellps=intl
 +towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68 +units=m +no_defs
 +datum=WGS84
 which are basically the same of the two layers I attached to this ticket
 but with the "+datum" parameter.
 I then saved the *same* layer in two version with the above crs, to see if
 with OTFR enabled and the project defined in WGS84 (+proj=longlat
 +ellps=WGS84 +datum=WGS84 +no_defs) the two align*.
 When loading the layer defined with B) qgis strips or ignores
 "+towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68"
 and shows just
 "+proj=tmerc +lat_0=0 +lon_0=9 +k=0.9996 +x_0=1500000 +y_0=0 +ellps=WGS84
 +datum=WGS84 +units=m +no_defs"
 As said, trying to choose manually the crs doesn't change the situation.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1875#comment:25>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
