[QGIS-trac] Re: [Quantum GIS] #1134: grass toolbox: can't unselect an optional map
Quantum GIS qgis at qgis.org
Wed Jun 24 10:21:49 EDT 2009
        Reporter:  hamish                            |         Owner:  rugginoso
            Type:  defect                            |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.3
       Component:  GRASS                             |       Version:  0.10.0
      Resolution:                                    |      Keywords:  grass toolbox
Platform_version:  Etch                              |      Platform:  Debian
        Must_fix:  Yes                               |   Status_info:  0
Comment (by hamish):
 Replying to [comment:3 rugginoso]:
 > I can't understand what do you mean about "can't unselect an optional
 map".
 > In the example you provided me (r.cost) you must select a layer into
 each combobox, so the choice to leave empty one of them is incorrect.
 yeah sorry, that's a bad example. in GRASS it is optional but in the QGIS
 wrapper it is not.
 In GRASS you can use specific coordinates, vector map points, or raster
 map pixels for the starting points. Apparently the QGIS wrapper for it
 only offers the chance to use a raster map for that, so it becomes a
 required option in QGIS.
 I'll have to hunt around for one that really shows the behaviour, although
 the effort to minimize module options in the QGIS wrappers may make it
 hard.
 the general idea is this: some modules take optional input maps with a
 default of none. (eg if input data comes from a vector map instead) If you
 use the pulldown menu to select a map for that option there is no way to
 get back to the "none" state.
 Hamish
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1134#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
