[QGIS-trac] [Quantum GIS] #1747: Identify Map Tool: QGis crashes when the results dialog has multiple features and the active layer is remove
Quantum GIS qgis at qgis.org
Wed Jun 24 10:44:36 EDT 2009
   Reporter:  gcarrillo                                                         |              Owner:  gcarrillo
       Type:  patch                                                             |             Status:  new
   Priority:  critical: causes crash or data corruption                         |          Milestone:
  Component:  Vectors                                                           |            Version:  HEAD
   Keywords:  identify map tool results dialog remove vector layer rubber band  |   Platform_version:
   Platform:  All                                                               |           Must_fix:  No
Status_info:  0        |
 layer is remove. When I select a feature from the results dialog it has no
 reference layer to draw the rubber band and get a segmentation fault. It
 happens on vector layers.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1747>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
