[QGIS-trac] Re: [Quantum GIS] #2078: [Windows] adding a GRASS raster created with r.external crashes QGIS
Quantum GIS qgis at qgis.org
Fri Feb 5 04:55:35 EST 2010
        Reporter:  pcav                                       |         Owner:  rugginoso
            Type:  bug                                        |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.5.0
       Component:  GRASS                                      |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  Windows
        Must_fix:  No                                         |   Status_info:  0
Comment (by lutra):
 Tested r12883 under XP and still crashes.
 The curios thing is that qgis crashes if you try add the raster from the
 grass browser but doesn't crash if you add the raster from the qgis grass
 toolbar. Nevertheless the raster doesn't show correctly and qgis shows the
 following message:
 Cannot draw raster
 Cannot start module
 command: C:/OSGeo4W/apps/qgis-dev/./grass/modules/qgis.d.rast.exe
 map=teste1 at demo
 window=-7.1176e+06,1.33306e+06,4.89704e+06,7.80968e+06,1170,631<br><br>ERRO:Unable
 to locate symbol <GDALAllRegister>
 The resulting raster is all grey and in the properties shows no color
 bands.
 As raster to test I used the one in the qgis demo dataset.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2078#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
