[QGIS-trac] Re: [Quantum GIS] #1878: remove setjmp/longjmp in grass plugin&provider and use exceptions instead
Quantum GIS qgis at qgis.org
Wed Jan 13 06:25:18 EST 2010
        Reporter:  jef                               |         Owner:  jef
            Type:  patch                             |        Status:  reopened
        Priority:  major: does not work as expected  |     Milestone:  Version 1.3.0
       Component:  GRASS                             |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  All
        Must_fix:  No                                |   Status_info:  0
Changes (by rblazek):
  * priority:  minor: annoyance => major: does not work as expected
Comment:
 For me it is still crashing, the exception is not caught. I tried to call
 a GRASS function and catch exception in libqgisgrass and also both moved
 to plugin, but it does not work. I have also recompiled GRASS 6.4 from
 source but nothing helped.
 It does not work even with reverted
 http://trac.osgeo.org/grass/changeset?old_path=grass%2Ftrunk%2Flib%2Fgis%2Ferror.c&old=23438&new_path=grass%2Ftrunk%2Flib%2Fgis%2Ferror.c&new=23439
 The change in GRASS above probably is not significant, G_fatal_error does
 not continue in execution after the installed error_routine was called,
 but the exception cannot be caught.
 Kbuntu 9.10, gcc (Ubuntu 4.4.1-4ubuntu8) 4.4.1, grass-6.4.0RC5, GDAL svn
 trunk, QGIS svn trunk, libstdc++6-4.4-dbg
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1878#comment:15>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
