[QGIS-trac] Re: [Quantum GIS] #1878: remove setjmp/longjmp in grass plugin&provider and use exceptions instead
Quantum GIS qgis at qgis.org
Wed Jan 13 07:47:59 EST 2010
        Reporter:  jef                               |         Owner:  jef
            Type:  patch                             |        Status:  reopened
        Priority:  major: does not work as expected  |     Milestone:  Version 1.3.0
       Component:  GRASS                             |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  All
        Must_fix:  No                                |   Status_info:  0
Comment (by rblazek):
 jef, I have created very simple test, attached (except.tar). Could you
 please try to just run 'make' and './test'? For me it does not work:
 ./test
 set_error_routine() start
 set_error_routine() end
 error_cpp called
 caught int from error_cpp
 error() start
 error_routine called
 terminate called after throwing an instance of 'int'
 Aborted (core dumped)
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1878#comment:16>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
