[QGIS-trac] [Quantum GIS] #2375: If there is any feature selected, QGIS crashes on exiting.
Quantum GIS qgis at qgis.org
Mon Jan 18 10:06:37 EST 2010
   Reporter:  trapanator                                 |              Owner:  jef
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.5.0
  Component:  Python plugins and bindings                |            Version:  HEAD
   Keywords:                                             |   Platform_version:
   Platform:  Windows                                    |           Must_fix:  Yes
Status_info:  0                                          |
 I've wrote a python plugin that selects some features and views them on
 the map.
 I found that if there's a particular PostGIS layer and you select some
 features from a Shapefile Vector layer, exiting QGIS crashes.
 To test a plugin, you can download the "Find attribute plugin 0.3" and
 modify it in order to view the selected features. I'll attach it anyway.
 Steps to reproduce:
 1) create a PostGIS layer whith the attached code;
 2) open QGIS;
 3) add the PostGIS layer;
 4) add a line multistring shapefile vector layer (i.e. roads);
 5) use the Find By Attribute 0.3 plugin and modify it in order to view
 selected features
 6) exit QGIS by clicking on "X" of the window
 7) QGIS crashes
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2375>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
