[QGIS-trac] Re: [Quantum GIS] #2375: If there is any feature selected, QGIS crashes on exiting.
Quantum GIS qgis at qgis.org
Mon Jan 18 17:40:57 EST 2010
        Reporter:  trapanator                                 |         Owner:  jef
            Type:  bug                                        |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.5.0
       Component:  Python plugins and bindings                |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  Windows
        Must_fix:  Yes                                        |   Status_info:  0
Comment (by lutra):
 I'm trying to replicate the issue but I'm not understanding much.
 Can you explain me what exactly to do in step 5)?
 The features to be selected are in the postgis layer created with the sql
 you attached or in the vector you say to add in step 4) ? What has one
 vector to do with the other?
 The findbyattr.py file you attached is to replace the original provided
 with the "find by attribute plugin"? If yes, should I see something
 different in the modified plugin? I tried and it seems the same to me.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2375#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
