[QGIS-trac] Re: [Quantum GIS] #3058: print composer: exporting to PDF does not resize correctly vectors if symbology is in mm. Works fine if units are map units.
Quantum GIS qgis at qgis.org
Fri Oct 29 08:55:21 EDT 2010
   Reporter:  lutra                             |              Owner:  mhugent
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.6.0
  Component:  Printing                          |            Version:  Trunk
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  Yes
Status_info:  0                                 |
Comment(by mhugent):
 I tested on several machines, and the printer output was usually close to
 15 mm. On screen, I had different results, it was correct on some and
 wrong on others (e.g. 11 mm instead of 15). I think this might be do to
 the fact that the x-server (and thus Qt) does not always give the correct
 dpi number.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3058#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
