[QGIS-trac] [Quantum GIS] #3467: Extremely Bloated PDF Export (Vector) under Linux.
Quantum GIS qgis at qgis.org
Fri Feb 4 22:31:57 EST 2011
   Reporter:  Thaddeus                                   |              Owner:  jef
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.7.0
  Component:  Printing                                   |            Version:
   Keywords:  PDF PostScript corruption                  |   Platform_version:  Ubuntu 10.10
   Platform:  Debian                                     |           Must_fix:  No
Status_info:  0                                          |
 Simply by applying "Buffer Labels" to an 8-letter label on a vector layer
 containing a single-feature  point creates more than a million (1314400
 --corrupted PS) lines of PostScript code that takes 5 minutes to display
 on a modern PC. Adding a few more features to label crashes Composer. The
 composer view used has just one item, a map object. This is under Ubuntu
 10.10 and QGIS 1.6.
 The attached example contains the QGS file, the point SHP file along with
 the malformed PDF printout.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3467>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
