[QGIS-trac] Re: [Quantum GIS] #3466: Extremely Bloated PDF Vector Export under Win.
Quantum GIS qgis at qgis.org
Mon Feb 28 13:24:08 EST 2011
   Reporter:  Thaddeus                          |              Owner:  jef
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Printing                          |            Version:
   Keywords:  Bloated PDF Vector Export         |   Platform_version:  win 1.6
   Platform:  Windows                           |           Must_fix:  No
Status_info:  0                                 |
Comment(by Thaddeus):
 Here is some test data:
 1-6-test.zip
 the QGS test file has two layers, an raster image showing a well defined
 edge --nice for hand tracing-- and a line-SHP layer with the trace of the
 raster layer: 8 small files in total.
 nada01_1-6_100dpi_vector_win2k.pdf
 This is the export-to-PDF result under Win2k.
 "StreamsFrom__ nada01_1-6_100dpi_vector_win2k.zip"
 This is the export-to-PDF result under Win2k with all streams unzipped
 using PDFtk and then dumping the streams using a script I wrote. 6 streams
 are readily identified as JPG objects, one has the funny PS code to frame-
 mask the images behind. 1 image is the off-place SHP trace (purple color)
 as a raster, which should really be vector, but blanking this object image
 reveals another raster (object at offset 16765?) copy of the same trace in
 green color now?. No vector data was found ??
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3466#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
