[QGIS-trac] [Quantum GIS] #3479: New Symbology does not print
Quantum GIS qgis at qgis.org
Wed Feb 9 13:08:47 EST 2011
   Reporter:  bderstine                         |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Printing                          |            Version:  1.6.0
   Keywords:                                    |   Platform_version:  Windows 7 Pro
   Platform:  Windows                           |           Must_fix:  Yes
Status_info:  0                                 |
 I have a linear feature layer (railroad lines).
 I wanted to create my own symbology for it since the default options are
 inadequate.
 Layer > Properties > New Symbology > select the railroad symbol >
 properties > add a new line, etc. to create two-track symbol with line
 offsets (see image attached)
 Create Print Composer, add map, add legend with layer using the new
 symbology.
 In the Print Composer the railroad symbology looks correct, but when you
 print to .pdf, .png or .jpg the image does not have the same symbology for
 railroad.  It is as if New Symbology is being completely ignored in the
 process of saving to a file. Perhaps the line offsets are being ignored?
 (see images attached)
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3479>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
