[QGIS-trac] Re: [Quantum GIS] #3295: SVG images rasterized when printing/exporting
Quantum GIS qgis at qgis.org
Wed Feb 9 18:14:58 EST 2011
        Reporter:  Alister                           |         Owner:  mhugent
            Type:  bug                               |        Status:  reopened
        Priority:  major: does not work as expected  |     Milestone:  Version 1.7.0
       Component:  Printing                          |       Version:  Trunk
      Resolution:                                    |      Keywords:
Platform_version:  7 64bit, XP 32bit                 |      Platform:  Windows
        Must_fix:  No                                |   Status_info:  0
Changes (by Alister):
  * platform_version:  7 64bit => 7 64bit, XP 32bit
  * type:  patch => bug
Comment:
 > Export of PDF results in groups of Images, pixelation if you look at
 sample (uploading now)
 I can confirm that, although it is different to the original bug.
 With current trunk on Windows XP an svg is not rasterised in the composer
 or when exported to svg or printed (whether to a real printer or a virtual
 PDF printer) but is rasterised when exported to PDF.
 > SVG export appears to be lines but is pretty much unusable in Inkscape,
 there are lots of random lines streaking across.
 I can't confirm this (it is OK on XP) and I think you should file a
 separate bug for it.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3295#comment:8>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
