[Qgis-us-user] Question on area calculations
Randal Hale rjhale at northrivergeographic.com
Fri Apr 13 06:14:53 PDT 2018
This has me puzzled. So I may have screwed up a very large job with
incorrect acres and I was doing what I thought I needed to be doing. I'm
probably doing this wrong - but if I'm doing this wrong there's a large
chance more people are doing the same.
This is all in QGIS 3.0.1
I have a forester who is working on a tract of land. There was a very
hurried cruise they needed to do.
Data is in WGS84 and set to EPSG:2240 in QGIS.
Change the ellipsoid to None under project properties:
  * using the identify button are 237 acres.
  * I get roughly 194 acres with the measure tool
Changing the ellipsoid to GRS1980 (which QGIS Defaults to):
  * I get 196 acres with the identify tool.
  *   I use the measure tool I get 194 acres
I am assuming the 194/196 measurements are the exact same and due to
human error on my part. PostGIS gives me 196 acres.
I guess (as I type this out) my correct course of action should be to
leave the ellipsoid in GRS1980 and do my work - BUT - I thought I could
drop back to none/planimetric if I set the projection to EPSG:2240 in QGIS.
Can anyone clue me in - I'm preparing for much yelling from the client
in about 15 minutes as I was off about 40 acres which was a costly
mistake. I'm not confident currently in my area measurements using QGIS
and I need to get confident.
Randy
Randal Hale
https://www.northrivergeographic.com
(423)653-3611
URL: <http://lists.osgeo.org/pipermail/qgis-us-user/attachments/20180413/23355813/attachment.html>
More information about the Qgis-us-user mailing list
