[Qgis-us-user] Need to find a translation for an error message
Randal Hale rjhale at northrivergeographic.com
Fri Apr 26 06:02:25 PDT 2024
It's "Unavailable Layer! Layer Data Source could not be found. Click to
set a new data source" in English.
On 4/26/24 08:55, Wilkes, Becky via Qgis-us-user wrote:
> The error message "The layer path has changed and no longer matches
> what is indicated" means that the individual layer (data file)
> locations have been changed and no longer match the file paths
> originally saved in the project. When you move layers or map files to
> different folders (using your operating system, most commonly Windows
> Explorer) and then open a QGIS project that still uses those old file
> paths, you’ll get this message.
> I’m not sure exactly what the message says in English, but it means
> that QGIS cannot find the files needed to complete the map display; in
> other words, there is a pathing (referencing) issue.  The way to fix
> it is to correct the source path from within QGIS.  That is, you need
> to tell QGIS the new locations of those files that are being displayed
> in the map, or the map will no longer display properly.
> Becky Wilkes, GIS Specialist, UNC
> *From:*Qgis-us-user <qgis-us-user-bounces at lists.osgeo.org> *On Behalf
> Of *Jessica Ball via Qgis-us-user
> *Sent:* Friday, April 26, 2024 4:54 AM
> *To:* qgis-us-user at lists.osgeo.org
> *Subject:* [Qgis-us-user] Need to find a translation for an error message
> Certaines personnes qui ont reçu ce courrier ne reçoivent pas souvent
> du courrier de la part de qgis-us-user at lists.osgeo.org. Découvrez
> pourquoi cela est important
> <https://aka.ms/LearnAboutSenderIdentification>
> Hello everyone,
> I am a translator in France and I am currently translating a training
> course for a French institution. I have downloaded the QGIS software
> and have been using the official QGIS user documentation to find the
> right terms. However, an error message in French is giving me a hard
> time. As I am not myself attending this training course I do not have
> the resources to make the error and therefore know how it is written
> in English, it is a message received if you move layers and then open
> a QGS projetct. In French it says: "/Le chemin des couches a changé et
> ne correspond plus à ce qui est indiqué dans le QGS/"
> Does anyone have an idea of what the software writes in English. If
> you have any suggestions it would be a great help.
> Thank you all and have a nice day
> Jessica Ball
> Qgis-us-user mailing list
> Qgis-us-user at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-us-user
North River Geographic Systems, Inc
https://northrivergeographic.com
URL: <http://lists.osgeo.org/pipermail/qgis-us-user/attachments/20240426/ef70dfe3/attachment-0001.htm>
More information about the Qgis-us-user mailing list
