[Qgis-user] Georeferencer
Carson Farmer cfarmer at uvic.ca
Wed Jul 2 11:19:11 PDT 2008
Agus,
> BTW, any way to georeference vectors?
Are you looking to actually 'warp' the vector layer, or simply
define/change its current projection? There is the 'srsmanagement' tool
which will define and project vector layers if this is what you are
looking for? It is available using this repository:
http://www.geog.uvic.ca/spar/carson/cfarmerQgisRepo.xml
If its warping the data, then you may have to do this manually using the
editing tools in QGIS...
Cheers,
Carson
