[Qgis-user] Georeferencer
Agustin Lobo Agustin.Lobo at ija.csic.es
Sun Jul 6 02:47:19 PDT 2008
As this is a digitized map (done outside QGIS), I have to define the
projection
and provide the coordinates for one point, which could
be understood as the most elementary warping (just a shift).
Perhaps I can do this with the editing tools?
Agus
Carson Farmer wrote:
> Agus,
>> BTW, any way to georeference vectors?
> Are you looking to actually 'warp' the vector layer, or simply
> define/change its current projection? There is the 'srsmanagement' tool
> which will define and project vector layers if this is what you are
> looking for? It is available using this repository:
> http://www.geog.uvic.ca/spar/carson/cfarmerQgisRepo.xml
> If its warping the data, then you may have to do this manually using the
> editing tools in QGIS...
> Cheers,
> Carson
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
