[Qgis-user] SSL Support in QGIS Builds, esp. Windows and MacOSX
Andreas Neumann a.neumann at carto.net
Thu Jul 17 06:44:17 PDT 2008
Hi Marco,
thanks for the info. So there is hope that the final 1.0 Windows version
will support SSL. This is good. Let me know if you need a tester.
Andreas
> Hi,
>> For the SSL libraries, those are part of the standard OSX system, no
>> worries there.  I don't know about Windows.
> I can tell about Windows; I must build OpenSSL library with MinGW because
> GRASS and QGIS (built with MinGW, along with all the other libraries,
> including PostgreSQL and SQLite) don't agree with Visual Studio built
> libraries. That means that I cannot enable OpenSSL support in PostgreSQL
> and
> SQLite since I build OpenSSL with MinGW. This is a task in my to-do list
> for
> WinGRASS-6.3.0-5 (or 6.4.0) and QGIS 1.0.
> Marco
> ----- Original Message -----
> From: "William Kyngesburye" <woklist at kyngchaos.com>
> To: "Andreas Neumann" <a.neumann at carto.net>
> Cc: "qgis-user" <qgis-user at lists.osgeo.org>
> Sent: Wednesday, July 16, 2008 9:22 PM
> Subject: Re: [Qgis-user] SSL Support in QGIS Builds, esp. Windows and
> MacOSX
>> On OSX, at least the way I and Tom package our builds, the postgres
>> client library is bundled in the Qgis application, so there is no need
>> to
>> worry about whether they are available in the system or not.   Windows
>> builds may do the same.
>> On Jul 16, 2008, at 1:58 PM, Andreas Neumann wrote:
>>> yes - my server has SSL enabled, but most of the client PCs and Macs
>>> don't have any Psql tools or libraries installed, and no openssl
>>> libraries, unless the OS provides one.
>>> No, QGIS doesn't block SSL (Marco and I tried it yesterday on Linux)  -
>>> but the OpenSSL libraries must be present on the clients - which  is
>>> usually not the case I think.
>>> Andreas
>>> William Kyngesburye wrote:
>>>> For OSX, SSL is enabled in my Postgres, and so should be available  in
>>>> my Qgis binaries.  I don't know about Tom's all-in-one Qgis build.
>>>> Unless there is something in Qgis blocking SSL?
>>>> On Jul 16, 2008, at 9:05 AM, Andreas Neumann wrote:
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> All generalizations are dangerous, even this one.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Andreas Neumann
Böschacherstrasse 6, CH-8624 Grüt/Gossau, Switzerland
Email: a.neumann at carto.net, Web:
* http://www.carto.net/ (Carto and SVG resources)
* http://www.carto.net/neumann/ (personal page)
* http://www.svgopen.org/ (SVG Open Conference)
* http://www.geofoto.ch/ (Georeferenced Photos of Switzerland)
