[Qgis-user] No projection systems available on 0.11 (ubuntu)
Maciej Sieczka tutey at o2.pl
Tue Jul 22 10:25:52 PDT 2008
Albin Blaschka pisze:
> after purging all qgis-related packages via aptitude purge I had to
> delete the following files manually, what I did:
> /etc/ld.so.conf.d/qgis.conf /home/albin/.qgis
> /home/albin/.config/QuantumGIS/qgis.conf /home/albin/.qgis/qgis.db
> /usr/lib/qgis /usr/lib/qgis/libqgis_core.so
> /usr/lib/qgis/libqgis_gui.so
Actually it should be necessary to remove those leftovers which come
with the packages, only. User settings (in your case files and dirs
under /home/albin) should not do any harm, and user propably prefers to
maintain them between upgrades.
Maciek
Maciej Sieczka
www.sieczka.org
