[Qgis-user] plugin installation
Martin Dobias wonder.sk at gmail.com
Thu Mar 6 17:11:16 PST 2008
On Fri, Mar 7, 2008 at 1:57 AM, Gary Sherman <sherman at mrcc.com> wrote:
> On Mar 6, 2008, at 11:42 AM, Martin Dobias wrote:
>  > Now I've found out that the problem is due to incorrect creation of
>  > directories - in some cases zip files, directories are not listed (in
>  > that case we create only top-level dir which leads to the problem with
>  > subdirectories).
>  > Fixed in trunk in r8191 but users of prebuilt packages will have to
>  > unpack the plugin manually.
>  The version prior to r8191 worked and was not the cause of the issue
>  in this thread. The problem is that the fix has not made it into a
>  released version yet.
Actually, I had the same error in my fresh svn trunk checkout so I
doubt that it was working ... were you able to install html_imagemap?
That .zip file doesn't list the directories, only files. So only the
top level directory was created which resulted in an error since that
.zip contains also some more subdirs which were not created.
Martin
